> Yet another 911 strut thread, Confustion about KONI inserts in KONI struts
Richard Casto
post Apr 22 2007, 10:29 AM
Blue Sky Motorsports, LLC
I am about to pull the trigger on a 911 front suspension. It is billed as being from a 72-74 911S (no the aluminum calipers are gone and I will be using regular A calipers instead) as it has KONI struts with the 3.5” spacing. Ultimately I am looking to install KONI Sport (aka Yellow) struts that have the adjustment knob on the top. I have read a few quality threads such as…
http://www.914world.com/bbs2/index.php?sho...c=390&st=20
This answers a lot of questions, but that thread mostly talks about Boge struts, spindle mods, etc. and doesn’t 100% clear up a question I have about KONI insert compatibility.
My confusion comes from the KONI application guide http://www.koni-na.com/pdfcatalogs/2007applguide.pdf (approx 1 MB PDF). If you don’t want to look at the PDF here is a summary of the KONI document …
65-68 911
Boge strut 86-1394 Classic
KONI strut 86-1308 Classic
69-74 911
Boge strut 8641-1039 Classic
KONI strut 86-1638 Classic
75-89 911
Boge strut 8641-1039 Special
KONI strut 86-1942 Special
(footnote) 8641-1039 Sport
914 and 914/6
All (Boge?) 8641-1077 Sport
To translate KONI types, Classic = “Black”, Special = “Red” and Sport = “Yellow”.
The implication is that "it appears" that you are really limited if you want to use the “Sport” insert as they only list the “Sport” strut for the 914 and 914/6 as well as for the 75-89 911 (but with a cryptic footnote). The 911 footnote says…
“Ext. adjust Sport alternative (both Boge and KONI) for OE KONI struts, gland nut 73.25.01.011.1 must be ordered separately”
My confusion/questions…
  • Is the dimensions/structure of all Boge struts the same and all KONI struts the same (I understand that Boge and KONI struts are not the same)? If so, using Boge struts as the example, ANY Boge “compatible” insert will “fit” ANY Boge strut regardless of the year of strut and model of insert?
  • That the KONI strut has a larger internal diameter and that the Boge is smaller? That the special gland nut they mention is first threaded into the KONI strut (Its external thread match the KONI struts threads) and then the Boge compatible KONI insert screws into the gland nut?
  • I am making a lot of assumptions here, but if the above is true about the gland nut, does that mean that you can take ANY of those KONI inserts and using the special gland nut use it in ANY of the Boge struts?
  • That the KONI application guide actually lists recommendations based upon OEM replacement and insert valving. For example if all of my above leaps of faith are correct (in that you can really mix and match) that if you do, you may just have incompatible insert valving that will affect handling dynamics. BUT it also means that you can use the proper 914 KONI "Sport" insert (that is properly valved for the 914) in any of the Boge or KONI 911 struts!?!?
  • This is more of a question for someone at KONI, but they list the 8641 “series” as being externally adjustable. Basically it looks like all of 8641 inserts are “sport” types. But the above into lists the KONI insert for the 75-89 Boge strut as “Special”, but not “Sport” even though it is an 8641 series insert. Maybe this is a misprint and it really is a Sport insert?
I know someone is going to say “Just use Boge struts”. I understand that my options are greater with the Boge, but I am really trying to settle my own confusion regarding the KONI struts. And if it works as I think it might, and then I may just go with the KONI struts front end that I am looking at.
One last thing…
I have tried to document everything that I have learned on the 914 Wiki. Please feel free to look at that article and if you think you know what you are talking about, correct any mistakes.
http://www.roadglue.com/wiki/index.php/911_front_suspension
Eric_Shea
post Apr 22 2007, 12:02 PM
PMB Performance
Didn't the 3.5 spacing come on the later cars? I thought they had only the 3" spacing up to 74. I could be mistaken, it's happend before.
3.5" began in 1969 with the first Koni strut and S-Calipers.
I have fairly early (still have the late model ball joint pins though) Koni struts on both of my cars. Both have had the spindles raised. I say this because on a Koni strut, you have a reduction in the tube where the spindle slips on. You can literally only raise it 18mm before you hit the flare. Boge's are different.
A 911 Boge strut is basically the same as any 914 Boge strut except the spindles are beefier on the 911 variety.
The main difference between the two is the fine (Koni I believe) threaded top and a more coarse threaded top on the Boge. That and the caliper mount spacing of course.. the Koni and Bilstein struts have the 3.5" mounts.
I'm no expert on this but, from working with mine, that's what I saw.
If you are planning on buying Koni's new, you may want to have them special ordered with the 914 valving. It's not "that" much different (only the high-speed rebound is different from what the Koni engineer told me) but it may make a difference.
Here's a bad picture that shows the difference in the tube (that old camera was actually dying Aaron... so don't post the flower icon macro bla,bla,bla (IMG:style_emoticons/default/biggrin.gif) ):
Richard Casto   Yet another 911 strut thread   Apr 22 2007, 10:29 AM
skline   Didn't the 3.5 spacing come on the later cars?...   Apr 22 2007, 10:55 AM
Eric_Shea   3.5" began in 1969 with the first Koni stru...   Apr 22 2007, 12:02 PM
Eric_Shea   Actually, this shows the flare in the tube better ...   Apr 22 2007, 12:16 PM
Richard Casto   Eric, thanks for jumping in! :D The photos o...   Apr 22 2007, 12:43 PM
Eric_Shea   I really don't think you'd be able to use ...   Apr 22 2007, 01:51 PM
Richard Casto   Ok, I talked to Bob at KONI and Jason at Paragon (...   Apr 23 2007, 03:37 PM
Eric_Shea   No I won't... :D After my chats with Koni t...   Apr 23 2007, 08:42 PM
rdauenhauer   Ok, I talked to Bob at KONI and Jason at Paragon ...   Feb 8 2009, 11:28 PM
Richard Casto   Rich, I am not sure what your question is. You q...   Feb 9 2009, 08:13 AM
Richard Casto   Here is a photo of my KONI strut and the 8641-1039...   Feb 9 2009, 08:21 AM
rdauenhauer   Danm~! :angry: :headbang: :welder:   Feb 9 2009, 05:14 PM
veltror   Apologies for the hijack but I think I might be ab...   Feb 10 2009, 02:29 PM
Eric_Shea   Those are non-usable junk. Please send them to me...   Feb 10 2009, 02:40 PM
Eric_Shea   Let me come back around to this... If they need r...   Feb 10 2009, 02:58 PM
Richard Casto   Roman, That is the exact same strut that I have (...   Feb 10 2009, 03:55 PM
Richard Casto   Forgot to mention this. You need to fill the spac...   Feb 10 2009, 04:02 PM
Eric_Shea   :agree: It's listed, with the fluid volume nee...   Feb 10 2009, 04:13 PM
veltror   You guys are great, so I could just order two 8641...   Feb 10 2009, 06:04 PM
Eric_Shea   You're going Koni to Koni so your pitch on tho...   Feb 10 2009, 06:13 PM
Richard Casto   You're going Koni to Koni so your pitch on th...   Feb 11 2009, 07:29 AM
veltror   :idea: I wish I was still living in the US, all ...   Feb 10 2009, 06:16 PM
Eric_Shea   Joking... I meant "I'm rather taken aback...   Feb 10 2009, 06:23 PM
ericread   Eric Shea; Aren't you out of the business now...   Feb 11 2009, 11:00 AM
- Lo-Fi Version Time is now: 9th June 2026 - 11:01 AM
