New shocks are awesome |
Joe Ricard |
Apr 23 2007, 10:57 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Koni race 8610-1473 inserts in front
AFCO threaded aluminum Body Coilover 1473 out back. Did a test and tune on crapped out Cantilevered slicks that no longer had any depth gauge holes. We ran the car for nearly 4 straight hours. only shutting off to make an adjustment. We learned that with the agressive rebound of the front shocks that the car would be held down on the front by nearly and inch after a run. I dropped the rear by that much. Gained a skid pad increase from 1.12 up to 1.21 sustained with consideraby more speed. Tweeked tire pressure and front rebound increase and went up to 1.27 with peaks of 1.31. We then started to tune throttle lift oversteer. Snapping the throttle closed and yanking the wheel and stabbing the gas just to see how we could get the car to hang out and rotate with power on. We had to quit because it was making us sick. Later in the day we set up a full autocross course and tuned some more with ride hieght down an 1/8" and made like 15 runns before we started to not be able top go any faster and could no longer put power down. We thought at 1st we made some wrong adjustment. I waked to the back of the car looked at the tires and said Hey suspension is good. WE GOT STRINGS nearly 1/3 the way across the inside edge of the tire. Put it on the trailer and called it a day. total success and we couldn't believe the tires lasted as long as they did. |
grantsfo |
Apr 23 2007, 11:35 AM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Sounds like a major improvement. Good work! What do you use to measure G's?
Since I have Traqmate its been fun to measure G's during track days. Doing skidpad testing would be very interesting. On the track my car was averaging 1.5 G's in some corners with some spikes as high as 2. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:29 PM |
