| Richard Casto |
Apr 22 2007, 10:29 AM
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
I am about to pull the trigger on a 911 front suspension. It is billed as being from a 72-74 911S (no the aluminum calipers are gone and I will be using regular A calipers instead) as it has KONI struts with the 3.5” spacing. Ultimately I am looking to install KONI Sport (aka Yellow) struts that have the adjustment knob on the top. I have read a few quality threads such as…
http://www.914world.com/bbs2/index.php?sho...c=390&st=20 This answers a lot of questions, but that thread mostly talks about Boge struts, spindle mods, etc. and doesn’t 100% clear up a question I have about KONI insert compatibility. My confusion comes from the KONI application guide http://www.koni-na.com/pdfcatalogs/2007applguide.pdf (approx 1 MB PDF). If you don’t want to look at the PDF here is a summary of the KONI document … 65-68 911 Boge strut 86-1394 Classic KONI strut 86-1308 Classic 69-74 911 Boge strut 8641-1039 Classic KONI strut 86-1638 Classic 75-89 911 Boge strut 8641-1039 Special KONI strut 86-1942 Special (footnote) 8641-1039 Sport 914 and 914/6 All (Boge?) 8641-1077 Sport To translate KONI types, Classic = “Black”, Special = “Red” and Sport = “Yellow”. The implication is that "it appears" that you are really limited if you want to use the “Sport” insert as they only list the “Sport” strut for the 914 and 914/6 as well as for the 75-89 911 (but with a cryptic footnote). The 911 footnote says… “Ext. adjust Sport alternative (both Boge and KONI) for OE KONI struts, gland nut 73.25.01.011.1 must be ordered separately” My confusion/questions…
One last thing… I have tried to document everything that I have learned on the 914 Wiki. Please feel free to look at that article and if you think you know what you are talking about, correct any mistakes. http://www.roadglue.com/wiki/index.php/911_front_suspension |
| Richard Casto |
Apr 23 2007, 03:37 PM
Ok, I talked to Bob at KONI and Jason at Paragon (both were VERY helpful and answered any question I came up with). Here is what I found out.
1. It sounds like the 69-89 Boge 911 struts are dimensionally the same, so you can mix and match inserts regarding fitment. However valving may be incorrect. I think the same holds true for the KONI struts of the same time period as well. I think the 68 and earlier 911 struts may be different (we didn’t talk much about them). So while the KONI application chart does not list a sport insert for the 72-74 KONI strut, you can use the insert designed for the 75-89 KONI strut in the 72-74 KONI strut. Basically the KONI charts are going to list OEM replacements (if they provide them) as well as upgrades to something like the Sport insert, but they it must both fit AND have proper valving before they are listed on the chart. Also, there might be a model that works (both fit and valving) for the front, but they don't have a model for the rear of the same type, so they will not list the front if they don't have a matching rear. Basically they are not going to recommend a Sport for the front if they don’t offer a Sport for the rear even if one of the other front Sport models would be just fine. 2. My quest to use the 8641-1077 914 Sport insert (which is should fit into a Boge strut) in the 911 KONI strut by using the special gland nut to convert from one thread pattern to another almost works, but there is a problem in that for some reason the 914 insert necks down much lower (near the bottom) on the insert than the 911 insert. This means that as you slide the insert it, it may bottom out before it is in position. Apparently it is VERY close to working as is, and that you can machine some metal off of the necking on the insert and it will fit, but at the risk of destroying or shortening the life of the insert. Apparently this used to be an issue with some of the 911 inserts and KONI moved the necking farther up the insert. But they haven't done the same for the 914 insert. So close, but no cigar. It is not a recommended solution. 3. I asked about the difference (if any) between the "8641-1039" and the "8641-1039 sport". I found it odd that there was an 8641 series insert that was not a "Sport" insert. They are different, but only in valving. Both have the same basic construction (single adjustable via the top screw), but the non-sport has less aggressive valving. 4. While I can use the 75-89 insert in the 72-74 strut and put it all in the 914 the valving is not going to be ideal. So while I can get that insert revalved to match the 914, there is another route as well. That would be to use the body of the 86-1638 (this is the natural replacement for the 72-74 KONI strut) and have it rebuilt using "Sport" internals (and of course valved appropriately) What am I going to do? I am going to pull the trigger on the 73 S front end that is available to me locally. I am going to eventually be buying the 8641-1039 Sport inserts. Eric will say that I will not be happy with the valving and if he is right, I will eventually get them revalved. |
Richard Casto Yet another 911 strut thread Apr 22 2007, 10:29 AM
skline Didn't the 3.5 spacing come on the later cars?... Apr 22 2007, 10:55 AM
Eric_Shea
3.5" began in 1969 with the first Koni stru... Apr 22 2007, 12:02 PM
Eric_Shea Actually, this shows the flare in the tube better ... Apr 22 2007, 12:16 PM
Richard Casto Eric, thanks for jumping in! :D
The photos o... Apr 22 2007, 12:43 PM
Eric_Shea I really don't think you'd be able to use ... Apr 22 2007, 01:51 PM
Eric_Shea
No I won't... :D
After my chats with Koni t... Apr 23 2007, 08:42 PM
rdauenhauer
Ok, I talked to Bob at KONI and Jason at Paragon ... Feb 8 2009, 11:28 PM
Richard Casto Rich,
I am not sure what your question is. You q... Feb 9 2009, 08:13 AM
Richard Casto Here is a photo of my KONI strut and the 8641-1039... Feb 9 2009, 08:21 AM
rdauenhauer Danm~! :angry: :headbang:
:welder: Feb 9 2009, 05:14 PM
veltror Apologies for the hijack but I think I might be ab... Feb 10 2009, 02:29 PM
Eric_Shea Those are non-usable junk. Please send them to me... Feb 10 2009, 02:40 PM
Eric_Shea Let me come back around to this...
If they need r... Feb 10 2009, 02:58 PM
Richard Casto Roman,
That is the exact same strut that I have (... Feb 10 2009, 03:55 PM
Richard Casto Forgot to mention this. You need to fill the spac... Feb 10 2009, 04:02 PM
Eric_Shea :agree: It's listed, with the fluid volume nee... Feb 10 2009, 04:13 PM
veltror You guys are great, so I could just order two 8641... Feb 10 2009, 06:04 PM
Eric_Shea You're going Koni to Koni so your pitch on tho... Feb 10 2009, 06:13 PM
Richard Casto
You're going Koni to Koni so your pitch on th... Feb 11 2009, 07:29 AM
veltror :idea:
I wish I was still living in the US, all ... Feb 10 2009, 06:16 PM
Eric_Shea Joking... I meant "I'm rather taken aback... Feb 10 2009, 06:23 PM
ericread Eric Shea;
Aren't you out of the business now... Feb 11 2009, 11:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 11:00 AM |
