| tomkirkcis |
Apr 29 2007, 07:55 PM
Newbie ![]() Group: Members Posts: 49 Joined: 19-October 06 From: massachusetts Member No.: 7,064 |
It's time for the front oil cooler. I am going to use a factory styule GT front bumper and valence. I expect to use a fiberglass repro of the factory oil cooler schroud. The factory cooler appears to be 19 1/2 inches long x 4" x 4" from the images of factory parts posted on the web. I can not find aftermarket coolers of the same size as the factory cooler The rx 7 cooler is longer and taller, 23 long x 5" x 2.5" Will it fit under a factory style schroud? Does anyone have pictures of an rx7 cooler install they have done?.
| woobn8r |
Apr 29 2007, 08:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None |
The RX7 cooler is a very good quality piece, but the inlet and outlet fittings are too small. if you cut them off and aluminum weld on proper fittings you must still have the cooler cleaned for metal particles...
With this modification it is a very nice alternative to other more expensive coolers...although the supply of new units is now a challenge....at least up here in Canada. There is enough cooling here for a racing six....maybe too cool for the average street four cyl... |
tomkirkcis remote oil cooler Apr 29 2007, 07:55 PM
Martin Baker I was steered away from the RX7 cooler by a knowle... Apr 29 2007, 08:15 PM
tomkirkcis
The RX7 cooler is a very good quality piece, but ... Apr 30 2007, 09:47 PM
woobn8r
The RX7 cooler is a very good quality piece, but... May 1 2007, 08:03 AM
nein14
[quote name='tomkirkcis' post='894959' date='Apr ... May 2 2007, 07:44 AM
yarin I have a stock rX7 cooler that I don't need. P... Apr 30 2007, 08:06 AM
race914 The Fluidyne 30618 is close in dimensions: 21... Apr 30 2007, 08:25 AM
tomkirkcis
The [url=http://www.fluidyne.com/pl_theoc.html#Th... Apr 30 2007, 10:01 PM
dekman I have a junkyard($15) RX-7 cooler and used e... May 9 2007, 12:06 AM
Justinp71 Is there more than one shroud option, that you can... May 10 2007, 05:33 PM
Maltese Falcon I've used many mazda RX4 coolers, that fit rig... May 10 2007, 09:44 PM
ninepfourteen
It's time for the front oil cooler. I am goi... May 17 2007, 05:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:46 PM |
