| chris914 |
Apr 29 2007, 10:34 PM
Member ![]() ![]() Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
My engine keeps running after I turn it off.
My Pertronic ignition died after hooking up the adapter for the tachometer. It was working for a while. But as I was tuning the carburetors the engine stopped running and wouldn’t start again. I disconnected the MSD and the engine still wouldn’t start. I put the points in and the engine started. Then I hooked the MSD and the engine started again. But when I turn off the key the engine keeps running Has anyone had this problem before? The power to the points/MSD is an original wire from the engine relay board. Should I run a separate wire from the ignition key? |
| Gint |
Apr 30 2007, 07:21 AM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
My car was doing that when I had the timing at idle very retarded. Since you were changing stuff out it's a possibility.
chris914 The engine keeps running after I turn off the key Apr 29 2007, 10:34 PM
Should I run a separate wire from the ignition ke... Apr 29 2007, 10:44 PM
iamchappy Power is leaking back into the system is keeping t... Apr 30 2007, 07:26 AM
Aaron Cox
Power is leaking back into the system is keeping ... Apr 30 2007, 05:38 PM
McMark :agree: with Aaron. Apr 30 2007, 06:20 PM
ejm Common problem... check the MSD troubleshooting in... Apr 30 2007, 06:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:26 PM |
