| chris914 |
Apr 29 2007, 10:34 PM
Member ![]() ![]() Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
My engine keeps running after I turn it off.
My Pertronic ignition died after hooking up the adapter for the tachometer. It was working for a while. But as I was tuning the carburetors the engine stopped running and wouldn’t start again. I disconnected the MSD and the engine still wouldn’t start. I put the points in and the engine started. Then I hooked the MSD and the engine started again. But when I turn off the key the engine keeps running Has anyone had this problem before? The power to the points/MSD is an original wire from the engine relay board. Should I run a separate wire from the ignition key? |
| iamchappy |
Apr 30 2007, 07:26 AM
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Power is leaking back into the system is keeping the MSD energized, a one way diode spliced into the the blue alternator wire either before the regulator or the wire running to the alternator light in the dash should solve it.
chris914 The engine keeps running after I turn off the key Apr 29 2007, 10:34 PM
Should I run a separate wire from the ignition ke... Apr 29 2007, 10:44 PM
Gint My car was doing that when I had the timing at idl... Apr 30 2007, 07:21 AM
Aaron Cox
Power is leaking back into the system is keeping ... Apr 30 2007, 05:38 PM
McMark :agree: with Aaron. Apr 30 2007, 06:20 PM
ejm Common problem... check the MSD troubleshooting in... Apr 30 2007, 06:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:26 PM |
