Is this shift rod bent? |
Gudhjem |
May 1 2007, 04:49 PM
Member Group: Members Posts: 133 Joined: 29-March 07 From: Castro Valley, CA Member No.: 7,629 Region Association: Northern California |
While pulling my shift rod to replace the 3 shift bushings and cone screws, I noticed the crown bushing in back was very loose inside its housing. The hole is sets into is a nice oval. I suppose I'lll go the JB Weld route, and see how that works.
The shift rod itself also looks to be worn where it slides through the crown bushing (see pic). It also looks like it might be bent, which could explain all the wear in the crown bushing housing. I know the bar isn't suppossed to be straight, but I would have though that the ends would at least have to sit on the same 2 planes. Mine doesn't look like it does,at least not exactly. Anyone know if this is how the shift rod is supposed to look, more or less? This is from a '73 2.0 side-shifter. Attached thumbnail(s) |
John |
May 1 2007, 10:07 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
From what I can see, you r shift rod looks "normal" for a rear sideshift bar.
Lo-Fi Version | Time is now: 9th June 2024 - 07:03 PM |
