Replacing an 009 with a Mallory, What do I need? |
terrymason |
May 3 2007, 09:45 AM
Member Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 |
I'm thinking about replacing my 009 distributor with a Mallory from air cooled. I currently have dual dells on a 1.8L engine. I've got a stock boshe blue coil.
Here are my questions: 1. Will I need to replace my coil, wires, or plugs with this upgrade? 2. Is this really as easy as dropping it in and timing the car? 3. Can I leave my ignition on and listen to the radio in my driveway, or will this burn up the mallory? 4. Will I be able to move this over when I swap to a 2.0? 5. Will this "interface" with my Innovative wide band o2 sensor at all? I don't really know what I mean here, just wondering if there may be more functionality. |
ConeDodger |
May 3 2007, 10:07 AM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I'm thinking about replacing my 009 distributor with a Mallory from air cooled. I currently have dual dells on a 1.8L engine. I've got a stock boshe blue coil. Here are my questions: 1. Will I need to replace my coil, wires, or plugs with this upgrade? No 2. Is this really as easy as dropping it in and timing the car? Yes 3. Can I leave my ignition on and listen to the radio in my driveway, or will this burn up the mallory? Yes 4. Will I be able to move this over when I swap to a 2.0? Yes 5. Will this "interface" with my Innovative wide band o2 sensor at all? I don't really know what I mean here, just wondering if there may be more functionality. If you have a weld in bung and an O2 sensor or you are just using the LM to tune with a tailpipe sniffer it will work. It doesn't "interface" directly if that is what you mean. |
ConeDodger |
May 3 2007, 10:08 AM
I'm thinking about replacing my 009 distributor with a Mallory from air cooled. I currently have dual dells on a 1.8L engine. I've got a stock boshe blue coil. Here are my questions: 1. Will I need to replace my coil, wires, or plugs with this upgrade? No 2. Is this really as easy as dropping it in and timing the car? Yes 3. Can I leave my ignition on and listen to the radio in my driveway, or will this burn up the mallory? Yes 4. Will I be able to move this over when I swap to a 2.0? Yes 5. Will this "interface" with my Innovative wide band o2 sensor at all? I don't really know what I mean here, just wondering if there may be more functionality. If you have a weld in bung and an O2 sensor or you are just using the LM to tune with a tailpipe sniffer it will work. It doesn't "interface" directly if that is what you mean. Wait... Not sure about the sitting in the driveway and listening to the radio... Anyone??? Does the Mallory burn up if it is sitting just right with an open ignition? |
Lo-Fi Version | Time is now: 10th June 2024 - 11:30 AM |
