My new 914 motivator, Ahhh that is nice... |
ConeDodger |
May 3 2007, 11:11 PM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
[flv]http://www.914world.com/videos/RobMotor.flv[/flv]
DanT |
May 4 2007, 10:04 AM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
sounds like your suspension is pretty much what we used to run in Bi class.
problem is you get nailed just as much for 140# rear springs as I do for 21mm front torsion bars AND 180# rears....ah the vagaries of our points system (IMG:style_emoticons/default/dry.gif) the submarine could be turned into a track car very easily...I think the guy is just trying to talk himself out of it.... I am surprised that is hasn't sold before now. |
grantsfo |
May 4 2007, 11:15 AM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
sounds like your suspension is pretty much what we used to run in Bi class. problem is you get nailed just as much for 140# rear springs as I do for 21mm front torsion bars AND 180# rears....ah the vagaries of our points system (IMG:style_emoticons/default/dry.gif) the submarine could be turned into a track car very easily...I think the guy is just trying to talk himself out of it.... I am surprised that is hasn't sold before now. In thinking about it I believe most of our suspensions are fairly similar for cars driving at Zone 7 events. I'm using 21mm front bar, original stock bushings, 19mm front torsions, 250 lb rear springs and Koni yellows in rear and Bilstien sports in the front. Essentially only effective change I made from my T4 setup was to add a little heavier spring rate when the six went in. Nothing special or trick ...yet. I havent looked at super zoomie T4 suspensions - have they done anything trick? |
ConeDodger |
May 4 2007, 11:21 AM
sounds like your suspension is pretty much what we used to run in Bi class. problem is you get nailed just as much for 140# rear springs as I do for 21mm front torsion bars AND 180# rears....ah the vagaries of our points system (IMG:style_emoticons/default/dry.gif) the submarine could be turned into a track car very easily...I think the guy is just trying to talk himself out of it.... I am surprised that is hasn't sold before now. In thinking about it I believe most of our suspensions are fairly similar for cars driving at Zone 7 events. I'm using 21mm front bar, original stock bushings, 19mm front torsions, 250 lb rear springs and Koni yellows in rear and Bilstien sports in the front. Essentially only effective change I made from my T4 setup was to add a little heavier spring rate when the six went in. Nothing special or trick ...yet. I havent looked at super zoomie T4 suspensions - have they done anything trick? I am considering that I may need 180# or better due to the increase in torque and HP. I like the Elephant Bushings but Muellers rollers would be nice too. I want a bigger front bar but I like the soft T bars... Chris Foley has got something new cooking on the stiffening the trailing bar area... |
Lo-Fi Version | Time is now: 8th June 2024 - 12:06 AM |
