VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,757 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
So, last night I was looking at my tub as it sat on the rotisserie. The bottom is done. I need to to some final sanding to the cabin and trunks, and then I can start masking spraying the epoxy primer.
I was thinking at first to take the car off the rotisserie first, and then paint it on jackstands. Now I am not too sure. On one hand, it iwll be way easier to paint the trunks, cabin and gas compartment with the car on the rotisserie. Sanding the build primre will also be easier on the rotesserie. On the other hand, the car is far more likely to be scratched removing the car from the Rot, and masking the underside might be easier with it on jackstands. So, opinions are wanted. On or Off? Epoxy primer and build primer on, and color off? Choices choices.... And with that, I must leave you to boldly walk into a dreary multi-hour meeting. Lets just hope it gets cut a bit short. Zach |
VaccaRabite |
Ok, it seems like my origional thoughts were just going to make lif harder on me. I'll leave it on the rig, and paint it like that. I'll just need to be more careful when I remove it.
Zach |
Lo-Fi Version | Time is now: 11th July 2025 - 09:03 AM |
