| JBart |
May 5 2007, 01:17 AM
UNDER CONSTRUTION ![]() ![]() Group: Members Posts: 110 Joined: 9-October 06 From: Wildomar Ca. Member No.: 7,019 |
I need some help here . I dropped my engine to fix some major oil leaks . I'm wondering if I can take this nonworking assy. out while I have the tin off I don't have a T-stat. so i'm thinking it won't hurt to remove them. Am I correct in my thoughts? Here are some pics. of what i'm talking about.
Thanks, jbart Attached image(s)
| computers4kids |
May 5 2007, 09:01 AM
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
(IMG:style_emoticons/default/smilie_pokal.gif) I would find a T-stat ,pulley.and wire to make the thing fuction properly. Porsche engineers disigned it that way for a reason. my 2 cents Dave (IMG:style_emoticons/default/slap.gif) Hi Sorry man, you got to keep em. Get the T-stat working, even in Cali. When you remove flaps in the cooling system, (they actually route air to the rite places,) the motor will run hotter in all the wrong places. The cooling system is very well thought of, but it needs to be working on a T4. Later (IMG:style_emoticons/default/beerchug.gif) Hi Sorry man, you got to keep em. Get the T-stat working, even in Cali. When you remove flaps in the cooling system, (they actually route air to the rite places,) the motor will run hotter in all the wrong places. The cooling system is very well thought of, but it needs to be working on a T4. Later (IMG:style_emoticons/default/beerchug.gif) I agree 100%. Street cars need these pieces to work. Everything is there for a very good reason. If this a street 914 you will be real sorry if you don't keep the flaps...by default if the thermostat cable breaks, the flaps are positioned for full cooling. You can buy a new thermostat and cable from evparts for less than $100. You want your engine to warm up...if not, the wear on the engine running cold longer comes at a high price. The type three coil opens 10 degrees sooner than the OEM type 4...but not that big of a deal. Attached image(s)
| Cap'n Krusty |
May 5 2007, 09:20 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
QUOTE "If this a street 914 you will be real sorry if you don't keep the flaps...by default if the thermostat cable breaks, the flaps are positioned for full cooling. You can buy a new thermostat and cable from evparts for less than $100. You want your engine to warm up...if not, the wear on the engine running cold longer comes at a high price. The type three coil opens 10 degrees sooner than the OEM type 4...but not that big of a deal." Of course you shouldn't let the fact that the T3 part won't fit get in your way ..................... How ya gonna attach the wire? T4 ones are available. For the street, running the flaps in the default position is a good option. The Cap'n |
| type47 |
May 5 2007, 09:43 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
QUOTE "If this a street 914 you will be real sorry if you don't keep the flaps...by default if the thermostat cable breaks, the flaps are positioned for full cooling. You can buy a new thermostat and cable from evparts for less than $100. You want your engine to warm up...if not, the wear on the engine running cold longer comes at a high price. The type three coil opens 10 degrees sooner than the OEM type 4...but not that big of a deal." Of course you shouldn't let the fact that the T3 part won't fit get in your way ..................... How ya gonna attach the wire? T4 ones are available. For the street, running the flaps in the default position is a good option. The Cap'n maybe he just mis-identified the type as i think it's actually a type I thermostat adapted to work on a type IV |
JBart Can I get rid of these ? May 5 2007, 01:17 AM
So.Cal.914 You live in CA so I don't see a problem, just ... May 5 2007, 01:20 AM
Dan (Almaden Valley) the one over the oil cooler can be rivited down to... May 5 2007, 01:21 AM
toon1 maybe the top one,maybe, if you have no plan to us... May 5 2007, 01:23 AM
JBart
maybe the top one,maybe, if you have no plan to u... May 5 2007, 01:26 AM
Dan (Almaden Valley) there is a pulley system on the bottom left side o... May 5 2007, 01:32 AM
BarberDave :trophy:
I would find a T-stat ,pulley.and wire... May 5 2007, 04:36 AM
MecGen Hi
Sorry man, you got to keep em. Get the T-stat ... May 5 2007, 07:10 AM
URY914
Hi
Sorry man, you got to keep em. Get the T-stat... May 5 2007, 08:23 AM
computers4kids
Of course you shouldn't let the fact that t... May 5 2007, 09:28 AM
computers4kids maybe he just mis-identified the type as i think i... May 5 2007, 10:00 AM
NO
you need the f... May 5 2007, 12:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:39 PM |
