OT: 8.8" FORD rear differential, Strange noises |
John |
May 5 2007, 05:56 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
My support vehicle 93 ford econoline, has some strange noises when I turn the rear wheels when up on a lift. Today is the first time I have had it up in the air, and I turned a rear wheel and heard horrible sounds. It sounded like a really bad bearing or something. The wheel turned kind of chunky (you could feel varying resistances as it was turned).
I pulled the diff cover off and found that the differential gears were causing the noises. I am assuming that this is NOT normal and that they are worn beyond their serviceable life. My question to you is: Should there be any noises when turning the raised rear wheels on a ford 8.8" rear end? Any suggestions? I have already ordered a rebuild kit (new spider gears, etc). Thanks for any help/suggestions you may have. |
Crazyhippy |
May 5 2007, 06:02 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Should be no noise. Read up on setting up the ring and pinion now. it takes some fine-tuning to get it right.
Did it make any noise while driving? |
Lo-Fi Version | Time is now: 9th June 2024 - 08:30 PM |
