OT: 8.8" FORD rear differential, Strange noises |
John |
May 5 2007, 05:56 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
My support vehicle 93 ford econoline, has some strange noises when I turn the rear wheels when up on a lift. Today is the first time I have had it up in the air, and I turned a rear wheel and heard horrible sounds. It sounded like a really bad bearing or something. The wheel turned kind of chunky (you could feel varying resistances as it was turned).
I pulled the diff cover off and found that the differential gears were causing the noises. I am assuming that this is NOT normal and that they are worn beyond their serviceable life. My question to you is: Should there be any noises when turning the raised rear wheels on a ford 8.8" rear end? Any suggestions? I have already ordered a rebuild kit (new spider gears, etc). Thanks for any help/suggestions you may have. |
MecGen |
May 6 2007, 08:22 AM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Hi Guys
Uhhm, when you got a viehicle on a lift turning in gears you will hear more noise, this is just because the planitary gears (spiders) are spinning around in the pig. How much more noise is the question, you did the rite thing, open and have a look. That diff had some issues with the pinion bearing getting loose, make sure you check it when the pig is out. I would strongly recommend an "anti-friction" additives for non posi units, your local PO will have it, it will add years to the diff. Play Safe Later (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 01:50 PM |
