Rear Brake Lines, Is there a trick to undoing them? |
fiid |
Nov 25 2003, 12:33 AM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
And please don't say "drop the engine" or "remove the heat exchangers".......
I am talking about the body side that is quite difficult to get to. Fiid. |
AZ914 |
Nov 25 2003, 10:25 AM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
I just did this last week. I had a leaky line and was upgrading to SS braided. I also could not get the 17mm on the rubber line in a manner that let me actually MOVE the damn thing.
I also did what was just suggested. If you are pitching the rubber lines, just cut them off below the fitting and stick a deep socket over the end. You should be able to get an 11mm flare wrench on the top fitting. and hold while spinning the socket. Good luck! |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:22 PM |
