Sail vinyl replacement, Removing the glue???? |
computers4kids |
May 9 2007, 10:31 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I replaced all my sail vinyl when I had the car painted a year ago...unfortunately one of the sails have a couple of air bubbles that have developed over the last year. I want to remove the vinyl and re-lay it down again.
My question...I should be able to get the vinyl up without hurting it...it was initially applied with 3M spray adhesive. I need to remove the glue off the car sail and the back of the vinyl. What is the best stuff to remove the glue on both surfaces without ruining the vinyl? Laquer thinner? Thanks |
John |
May 9 2007, 10:34 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
On the car, I would use 3M adhesive remover. It works well. On the vinyl, I am not sure. You could try using the remover on the vinyl as well , but you may want to use small amounts to make sure that it is not damaged.
Just my $0.02 |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:59 PM |
