Vents & Jetting 44 IDF's for 2.0 |
bobhasissues |
May 11 2007, 01:16 PM
seemingly endless issues with my 914 Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None |
I'm trying to get my 2.0 to run with Weber 44 IDF's. Can anyone share sizes of Main Venturi, Main Fuel and Air Corrector jets for a stock 2.0? What's working for you? There's a lot of conflicting information out there regarding the venturi. Some say 28mm while others say the 36mm will work. I would really appreciate feedback from someone with firsthand experience.
ws91420 |
May 12 2007, 08:03 AM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Is there a way to determine vent size w/o disassembly or w/o having to get gaskets for a rebuild?
bperry |
May 12 2007, 12:29 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
Is there a way to determine vent size w/o disassembly or w/o having to get gaskets for a rebuild? If they are unmodified weber venturis, they will have the size cast into the top of the vent. Using a flashlight you should be able to see it by looking down from the top. It will be a raised number along the mid to upper edge. Mine came from the factory with the numbers directly under the accelerator pump jets. Still readable though. See photo below --- bill |
Lo-Fi Version | Time is now: 16th June 2024 - 03:54 AM |
