| r_towle |
Nov 20 2003, 08:40 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
What is the racing trick to keep these sucker tight???
Is it just part of weekly maintenance??? Or, is there a fabbed kit out there to put in longer bolts and a nylon nut on the back? Or, how about drilling out the heads and wiring them in somehow????? Rich |
| ArtechnikA |
Nov 25 2003, 09:01 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
QUOTE(r_towle @ Nov 20 2003, 06:40 AM) What is the racing trick to keep these sucker tight??? ... Or, how about drilling out the heads and wiring them in somehow????? yes, new washers, every time. torque the fasterners to spec, 33 lbs/ft IIRC. i drill them for safety wire, no 'somehow' to it, really. i wire them in pairs. standard 0,032" safety wire twisted with safety wire pliers. hit the side of the head with a small grindstone in a Dremel, then use a 1/16" cobalt bit in a drill press; use plenty of cutting oil, NBD. i like to re-torque the inboard ends after a week of road use and then wire them, the outboard ends get it before installation. some use a half-height Nylock nut on "too long" bolts; i've never done that but i'm sure it'd work. |
r_towle CV joint Bolts Nov 20 2003, 08:40 AM
brant Use the factory style correct lock washers....
Use... Nov 20 2003, 09:11 AM
redshift Yes yes. Make sure the new ones you use are super-... Nov 20 2003, 09:14 AM
r_towle Are these the wavy washers or conventional lock wa... Nov 20 2003, 09:18 AM
James Adams <... Nov 20 2003, 09:28 AM
edgetoo I believe that the washers are narrowand seriated.... Nov 20 2003, 09:32 AM
brant But the trick in my opinion.. is to use New or nea... Nov 20 2003, 09:55 AM
r_towle Thanx, found em,,,, look worn out I think a new se... Nov 20 2003, 10:07 AM
fuch toy Saw a set someplace....had holes drilled it the he... Nov 20 2003, 10:28 AM
James Adams Part # 999 523 102 01 Nov 20 2003, 10:35 AM
Qarl Lookie lookie... 3 bags of schnorr washers came to... Nov 25 2003, 06:40 PM
Brad Roberts Karl..
why in the world would you order that damn... Nov 26 2003, 12:49 AM
redshift That killed me too...
I don't think I have ev... Nov 26 2003, 01:11 AM
Qarl I like to make necklaces out of them.
Actually th... Nov 26 2003, 01:22 AM
redshift You need to get to sleep, so you can work tomorrow... Nov 26 2003, 01:24 AM
Qarl :finger: ha ha Nov 26 2003, 01:26 AM
Brad Roberts Damn it Miles... let me be depressed... stop makin... Nov 26 2003, 01:40 AM
Qarl Yeah yeah... make your fun.
If you can find a cur... Nov 26 2003, 09:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 09:31 PM |
