> [OT]50°f (or less) in garage, I need heat !!!!, propane, thermals, burn my waste oil????
Mueller
post Nov 24 2003, 09:12 PM
914 Freak!
okay, it's starting to cold here and working in the garage is not fun at this moment (cold floor, cold tools...everything is cold !!! )
how good are the heaters that use a propane tank?
~how long to they last??
I finally had to turn on the heater inside the house this week....even as cheap as I am, 60° is getting into the uncomfortable zone.....damn, there goes my PG&E bill (IMG:style_emoticons/default/sad.gif)
Mark Henry
post Nov 25 2003, 11:38 PM
that's what I do!
My shop is a 1800sq/ft pole barn with R-20 walls and R-40 ceiling built to R-2000 standard. Wood heat, it takes 1 1/2 bush cords to heat each winter. It costs me $350 Canadian for 2 bush cords, that is cut, split and delivered.
I built my shop myself in '96, my house was built in '83 and takes 4X that to heat it. (IMG:style_emoticons/default/mad.gif)
Mueller   [OT]50°f (or less) in garage, I need heat !!!!   Nov 24 2003, 09:12 PM
rick 918-S   I have slab heat but I screwed up on the size of t...   Nov 24 2003, 09:19 PM
Aaron Cox   use a small thermonuclear device   Nov 24 2003, 09:22 PM
Pnambic   If you've got a Magnesium engine case or trann...   Nov 24 2003, 10:02 PM
rick 918-S   When they come out with the new F150 you could get...   Nov 24 2003, 10:10 PM
!   I have one of those Bazzooka heaters that hook up ...   Nov 24 2003, 10:21 PM
fiid   ...   Nov 25 2003, 09:21 AM
r_towle   Mueller, There are a few things I do. I have man...   Nov 25 2003, 09:37 AM
!   Mueller, here's the one don't use no mo......   Nov 25 2003, 09:53 AM
Mueller   Thanks Mike, but I'll have to pass........... ...   Nov 25 2003, 11:25 AM
airsix   Why hasn't anyone suggested putting on pants a...   Nov 25 2003, 11:32 AM
!   When it gets cold here....I put on socks with my U...   Nov 25 2003, 11:43 AM
Qarl   Did I mention it's about 80 degrees outside to...   Nov 25 2003, 11:47 AM
jonwatts   Try to brag all you want Ellzey, you get about 2 w...   Nov 25 2003, 11:56 AM
rick 918-S   <...   Nov 25 2003, 11:56 AM
scotty   Heat with wool ;) Seriously, stay away from fl...   Nov 25 2003, 12:00 PM
SteveSr   <...   Nov 25 2003, 10:04 PM
Mark Henry   My shop is a 1800sq/ft pole barn with R-20 walls a...   Nov 25 2003, 11:38 PM
Eric_Shea   Try This Link   Nov 26 2003, 11:40 AM
jkeyzer   As Brad knows I do almost all of my work OUTSIDE b...   Nov 26 2003, 12:20 PM
r_towle   Eric, That is one scary looking contraption.... I...   Nov 26 2003, 12:31 PM
Dave Avery   Eric, rofl... I like it, but did you read the igni...   Nov 26 2003, 12:49 PM
Eric_Shea
  Nov 26 2003, 01:25 PM
ss6   I tried the non-vented propane heater and electric...   Nov 26 2003, 01:28 PM
Dave Avery   What about a couple of these? http://www.lowes.co...   Nov 26 2003, 02:12 PM
Dave Avery   Got two that look good: One, the 7060, which is a...   Nov 26 2003, 03:09 PM
ss6   depends on what you're doing. The radiants wi...   Nov 26 2003, 04:37 PM
joea9146   David: John SS6 is right you need something tha...   Nov 26 2003, 06:58 PM
- Lo-Fi Version Time is now: 13th July 2025 - 07:45 PM
