> 914 megasquirt info- Scott's 1.7
Scott-thundercat
post May 14 2007, 11:31 AM
hey, just bought a megasquirt complete kit from DIYautotune. saw a few good threads about em with 914's on here. any other suggestions? i have a stock 1.7 liter. reason i bought it is that my fuel trigger points went out, so 195 vs 145 it wasnt a tough decision since i've been wanting to build one for a few years now.
anyhow any help or tuning tables would be appreciated! i saw the 2 liter tuning tables. anything for a 1.7?
hex123
post May 15 2007, 06:27 PM
The tps is very easy I grabbed one from the junk yard off a 88 nissan 200sx
it has the same D shaped hole that mounts into the existing throttle body shaft. Someone here I think used one from a 88 mazda mx6. you just need a tiny bit of 1/4 in aluminium plate drill some alternate holes to be able to mount it. if you dont want to go to the junk yard I think nissan one is only 60$ or less new at the FLAPS
This mod is popular enough that we need to keep this thread going. no surprise but the MS forums dont have much with regard to installing and tuning on a 914,
Scott-thundercat   914 megasquirt info- Scott's 1.7   May 14 2007, 11:31 AM
yarin   Check my sig for pics of my install. I posted a lo...   May 14 2007, 11:55 AM
toon1   which version did you buy? MS-I, 2 , V-2.2,3.0? ...   May 14 2007, 12:12 PM
Scott-thundercat   thanks for the quick response guys. version 3 PCB...   May 14 2007, 03:49 PM
toon1   MS-I V.3 three is a good buy. It has alot of optio...   May 14 2007, 05:18 PM
rfuerst911sc   If anyone needs the LC1 O2 sensor itself I have tw...   May 14 2007, 05:43 PM
brer   I'm working on a MSI v3.0 right now as well. ...   May 15 2007, 03:01 PM
bd1308   brer, the MS will actually calculate FI fuel amou...   May 15 2007, 03:05 PM
toon1   the MAP sesnor is the most important item in the M...   May 15 2007, 04:01 PM
hex123   :agree: The tps is very easy I grabbed one from ...   May 15 2007, 06:27 PM
Scott-thundercat   thanks for all the input guys! so far i am on...   May 21 2007, 02:15 AM
Scott-thundercat   nevermind forgot i put pertonix in it! so a ha...   May 21 2007, 02:18 AM
Scott-thundercat   hmmmm. so i have a hall sensor- but i am going to ...   May 21 2007, 02:34 AM
mrhurtalot   whats the cost for a system fora 2.0? id love thi...   May 21 2007, 02:49 AM
Mueller   whats the cost for a system fora 2.0? id love th...   May 21 2007, 03:32 AM
DNHunt   Mike, I think for $247 you get to solder. Not...   May 21 2007, 08:48 AM
toon1   thanks for all the input guys! so far i am o...   May 21 2007, 09:46 AM
yarin   [quote name='Scott-thundercat' post='903058'...   May 21 2007, 09:03 PM
Rick_Eberle   :agree: I'm with the other guys, build it wit...   May 22 2007, 01:31 AM
brer   Hey, I've created a public folder for megasqui...   May 22 2007, 11:05 AM
toon1   Hey, I've created a public folder for megasqu...   May 22 2007, 11:10 AM
brer   PM me with email address to be sent an invitation ...   May 22 2007, 11:15 AM
Scott-thundercat   took the advice and built in everything. i ended ...   May 22 2007, 04:09 PM
Scott-thundercat   hey got it all in and wired- now to see if i can f...   May 25 2007, 10:29 PM
Scott-thundercat   okay- so went to try and start it- the fuel pump r...   May 26 2007, 01:06 AM
toon1   not sure about the pump relay, could be a transist...   May 26 2007, 01:24 AM
Scott-thundercat   okay found out i wired the fuel pump relay wrong- ...   May 26 2007, 09:02 PM
toon1   Hey Scott, ARE YOU RUNNING RESISTORS OR PWM%?...   May 26 2007, 09:34 PM
Scott-thundercat   pwm% i'm running no easy therm- dont know wha...   May 26 2007, 09:47 PM
toon1   OK, use these settings for WE -40*F: 100 ...   May 26 2007, 10:03 PM
Scott-thundercat   http://img.photobucket.com/albums/v447/Scott-thund...   May 26 2007, 10:34 PM
toon1   Ho are you setting your VE table? Are you using...   May 26 2007, 11:26 PM
Scott-thundercat   yeah i used megatune to do it. does it not look r...   May 26 2007, 11:37 PM
toon1   your KPA settings are upside down. are you goin...   May 26 2007, 11:50 PM
Scott-thundercat   okay i copied the table manually in the correct or...   May 27 2007, 12:10 AM
toon1   Strange that it formed like that, maybe mine is wr...   May 27 2007, 12:38 AM
Scott-thundercat   okay started up but died nearly at the same time a...   May 27 2007, 02:40 PM
toon1   okay started up but died nearly at the same time ...   May 28 2007, 01:28 AM
Scott-thundercat   they were 340 cc VW injectors. now have the stoc...   May 29 2007, 12:25 AM
toon1   how long does it run before it dies?   May 29 2007, 09:20 AM
Scott-thundercat   got it to run for 20 seconds at one point. usuall...   Jun 17 2007, 08:01 PM
Scott-thundercat   okay now here's a real puzzler... I have been...   Jul 19 2007, 10:49 PM
Scott-thundercat   So i got it running! turns out that i had use...   Aug 21 2007, 05:14 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:53 PM
