ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
When you modify your car, eliminating what the Porsche engineers designed you have to replace it or risk the consequences. In the case of the oil breather lines that used to go to your intake you risk oil leaks because of pressure and such...
Chris Foley of CFR has come up with the best solution I have seen. It takes the oil vapor from the heads and crankcase and if it pools, automatically drains it back to the engine. See the pic below. Chris would like to build a run of these but in order to justify the time and keep down the costs he needs to build a bunch. So... Once again it is Group Buy time in 914World. Indicate your interest here and Chris will give us details on cost and payment... Attached image(s) ![]() |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I've never liked how the hoses tie into the heads with a metal nipple just stuck into a hole in the head. Doesn't seal too well.
ConeDodger |
URY914 |
I've never liked how the hoses tie into the heads with a metal nipple just stuck into a hole in the head. Doesn't seal too well. Are you doing something else then Paul? Not really, but I should JB weld the nipple to the head than use a hose clamp on the hose to nipple connection. Always found it stupid to use a hose clamp on the hose when you can pull the nipple out of the head with little effort. |
Lo-Fi Version | Time is now: 10th June 2024 - 10:36 AM |
