Original Inside Rear Window Question, Trim on the inside at bottom of glass? |
swm914 |
May 15 2007, 10:43 AM
Member Group: Members Posts: 82 Joined: 28-January 07 From: Palmyra, PA Member No.: 7,484 Region Association: None |
Originally, was there any kind of factory trim running along the bottom of the rear glass where it meets the back of the inner cockpit? My car had a sticky film, somewhat uniform in width running along the bottom of the glass as if something had been glued or stuck there at one time. On part of the distance, I found black electrical tape. I assume the tape must have run the whole way at one time and was put there by a PO as "trim" and where the tape was missing, there was residue.
I removed all the tape and remaining sticky residue and it looks much better. However, it got me to wondering if there was a "trim" of sorts or whatever along there originally that he tried to duplicate with the electrical tape or if he was just being creative? Hopefully, I've described the area I'm talking about good enough. If not, I'll attach a pix when able. Thanks. Steve |
1970 Neun vierzehn |
May 16 2007, 04:05 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Hi Guys, BTW: Why don't you guys buy a set of factory manuels, It's in there and factory correct. Tom, "cause it's way more fun to post and see the responses, hijack threads, "push buttons", call names and point fingers. (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/mueba.gif) |
TJB/914 |
May 16 2007, 07:59 PM
Mid-Engn. Group: Members Posts: 4,330 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
Hi Guys, BTW: Why don't you guys buy a set of factory manuels, It's in there and factory correct. Tom, "cause it's way more fun to post and see the responses, hijack threads, "push buttons", call names and point fingers. (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/mueba.gif) Ha Ha (IMG:style_emoticons/default/av-943.gif) I knew the answer before you said it. We are family & need each other. T |
Lo-Fi Version | Time is now: 22nd May 2024 - 09:45 PM |
