rettigdw914 |
Newbie ![]() Group: Members Posts: 16 Joined: 17-September 04 From: Greenwood, IN Member No.: 2,774 ![]() |
Long time reader, first time poster here. If it wasn't for all of the great info on this site, I wouldn't have come half as far as I have on this project.
The problem I am having is at 60degF. ambient, cold engine, the car starts, jumps to 2000rpm for about 5seconds, then sputters and dies. It is very repeatable. Does this sound like a vacuum leak or ignition problems or other? Parts replaced/checked: Rebuilt fuel pump(30psi solid), Injectors flow tested and ultrasonically cleaned(4ml for 10sec crank) Rebuilt MPS from Bret, also used another Bosch original. Used two different ECMs TPS calibrated All electrical loads to ECU resistance checked per pbanders site. All Vacuum lines replaced, not all German hose but has good fit Injector seals replaced Intake runner gaskets and hose to plenum replaced Checked cork gasket on oil fill cap and is old but sealing Rebuilt distributor New points,condenser,cap,rotor,coil, wires,plugs(.024") Dwell is 42deg., out of spec. but should still run. right? Timing set to 27 deg bef. TDC, but I have been moving the dizzy around. Valves checked, OK I might try the carb cleaner trick to check for vacuum leaks but any other ideas are appreciated and welcomed. Things not replaced are: TPS gasket, Cold start seal?, AAR(it is open, not sure if closes) Thanks, -Don |
rettigdw914 |
OK, I had the neighbor come over and watch the fuel pressure gage. After the car started, then dies, Fuel pressure was 30 psi continuous until the fuel pump stops of course. So I think fuel flow is good. -- thanks Rich and Geoff.
One other thing I checked was compression, it was 120psi +/- 5, but when I pulled the plugs out they were all sooty black. I think this indicates running rich. The dial on my ECU is set at the manufacturers mark for LEAN/RICH. I also found another 1.7 914 for sale and put my MPS on it and it ran fine. any other ideas welcome. I hope I don't need another part, my wife won't like it too much. |
Lo-Fi Version | Time is now: 1st July 2025 - 03:46 AM |
