| Scott-thundercat |
May 14 2007, 11:31 AM
Member ![]() ![]() Group: Members Posts: 159 Joined: 16-October 06 From: Reno, NV Member No.: 7,049 |
hey, just bought a megasquirt complete kit from DIYautotune. saw a few good threads about em with 914's on here. any other suggestions? i have a stock 1.7 liter. reason i bought it is that my fuel trigger points went out, so 195 vs 145 it wasnt a tough decision since i've been wanting to build one for a few years now.
anyhow any help or tuning tables would be appreciated! i saw the 2 liter tuning tables. anything for a 1.7? |
| toon1 |
May 26 2007, 09:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Hey Scott,
ARE YOU RUNNING RESISTORS OR PWM%???? this is VERY IMPORTANT ARE YOU RUNNING EASY THERM? I would turn off the 02 sensor for now. get the car running first answer the Q's before you try to start the car again. The reason I say this is, your AE table is off. The AE table is directly related to the req fuel #. Your req. fuel is off ALSO, if you are not running ET( easy therm) your setting for you WE ( warmup enrichment) is wrong. These are all important for start up and keeping the engie running. There are quite a few things wrong with the settings we will address them later. I have my lap top up with the settings I am running. Keith |
Scott-thundercat 914 megasquirt info- Scott's 1.7 May 14 2007, 11:31 AM
yarin Check my sig for pics of my install. I posted a lo... May 14 2007, 11:55 AM
toon1 which version did you buy? MS-I, 2 , V-2.2,3.0? ... May 14 2007, 12:12 PM
Scott-thundercat thanks for the quick response guys. version 3 PCB... May 14 2007, 03:49 PM
toon1 MS-I V.3 three is a good buy. It has alot of optio... May 14 2007, 05:18 PM
rfuerst911sc If anyone needs the LC1 O2 sensor itself I have tw... May 14 2007, 05:43 PM
brer I'm working on a MSI v3.0 right now as well.
... May 15 2007, 03:01 PM
bd1308 brer,
the MS will actually calculate FI fuel amou... May 15 2007, 03:05 PM
toon1 the MAP sesnor is the most important item in the M... May 15 2007, 04:01 PM
hex123 :agree:
The tps is very easy I grabbed one from ... May 15 2007, 06:27 PM
Scott-thundercat thanks for all the input guys! so far i am on... May 21 2007, 02:15 AM
Scott-thundercat nevermind forgot i put pertonix in it! so a ha... May 21 2007, 02:18 AM
Scott-thundercat hmmmm. so i have a hall sensor- but i am going to ... May 21 2007, 02:34 AM
mrhurtalot whats the cost for a system fora 2.0? id love thi... May 21 2007, 02:49 AM
Mueller
whats the cost for a system fora 2.0? id love th... May 21 2007, 03:32 AM
DNHunt Mike, I think for $247 you get to solder. Not... May 21 2007, 08:48 AM
toon1
thanks for all the input guys! so far i am o... May 21 2007, 09:46 AM
yarin
[quote name='Scott-thundercat' post='903058'... May 21 2007, 09:03 PM
Rick_Eberle :agree: I'm with the other guys, build it wit... May 22 2007, 01:31 AM
brer Hey, I've created a public folder for megasqui... May 22 2007, 11:05 AM
toon1
Hey, I've created a public folder for megasqu... May 22 2007, 11:10 AM
brer PM me with email address to be sent an invitation ... May 22 2007, 11:15 AM
Scott-thundercat took the advice and built in everything. i ended ... May 22 2007, 04:09 PM
Scott-thundercat hey got it all in and wired- now to see if i can f... May 25 2007, 10:29 PM
Scott-thundercat okay- so went to try and start it- the fuel pump r... May 26 2007, 01:06 AM
toon1 not sure about the pump relay, could be a transist... May 26 2007, 01:24 AM
Scott-thundercat okay found out i wired the fuel pump relay wrong- ... May 26 2007, 09:02 PM
Scott-thundercat pwm% i'm running
no easy therm- dont know wha... May 26 2007, 09:47 PM
toon1 OK, use these settings for WE
-40*F: 100
... May 26 2007, 10:03 PM
Scott-thundercat http://img.photobucket.com/albums/v447/Scott-thund... May 26 2007, 10:34 PM
toon1 Ho are you setting your VE table?
Are you using... May 26 2007, 11:26 PM
Scott-thundercat yeah i used megatune to do it. does it not look r... May 26 2007, 11:37 PM
toon1 your KPA settings are upside down.
are you goin... May 26 2007, 11:50 PM
Scott-thundercat okay i copied the table manually in the correct or... May 27 2007, 12:10 AM
toon1 Strange that it formed like that, maybe mine is wr... May 27 2007, 12:38 AM
Scott-thundercat okay started up but died nearly at the same time a... May 27 2007, 02:40 PM
toon1
okay started up but died nearly at the same time ... May 28 2007, 01:28 AM
Scott-thundercat they were 340 cc VW injectors. now have the stoc... May 29 2007, 12:25 AM
toon1 how long does it run before it dies? May 29 2007, 09:20 AM
Scott-thundercat got it to run for 20 seconds at one point. usuall... Jun 17 2007, 08:01 PM
Scott-thundercat okay now here's a real puzzler... I have been... Jul 19 2007, 10:49 PM
Scott-thundercat So i got it running! turns out that i had use... Aug 21 2007, 05:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:07 PM |
