> Car not started for two years: Advice, In "cold storage" in Michigan
orthobiz
post May 25 2007, 05:29 PM
I'm getting my mint 74 1.8 liter soon, and as some of you may know, I looked hard this winter before I found my perfect ride. Along the way I found out about a car in Grand Rapids, Michigan, owned by a fellow who spends the winter in Florida. He's now back in Michigan and is getting ready to sell his car. It's a yellow 74 or 75 (he's not really sure) and it may or may not have some rust ("a little around the turn signals"), etc.
So, now I'm thinking "daily driver" because I've gotten this 914 bug really, really bad this year. What could be bad about having TWO cars???
The problem is he has not started it for two years. Probably has untreated gas in the tank, who knows how much gas. And it was stored in a covered pole barn that is unheated (which means zero degrees in Michigan winter).
Can you just charge the battery and try to start it up? Does the tank need to be drained and the lines changed or flushed or what??? Any idea of how long sitting is "too long?"
Thanks for the advice!
Paul
VaccaRabite
post May 27 2007, 11:32 AM
En Garde!
To get rid of gas, call your local FLAPS and ask where to drop it, or ask the local garage if they will take it (usually yes, but charge a small fee). Or, put it in a gas can, and drop it off at the local fill up joint, put a sign "free gas" and watch the fight erupt as you leave.
When I drained my tank, I just put it right in my Subaru. It was 2 years old, and the car ran fine.
Zach
orthobiz   Car not started for two years: Advice   May 25 2007, 05:29 PM
BarberDave   :trophy: ...   May 25 2007, 05:39 PM
RoninEclipse2G   to be safe I'd drain the tank, inspect the har...   May 25 2007, 05:42 PM
jd74914   if it had oil, I would change that too If it d...   May 25 2007, 05:52 PM
Porsche Rescue   While two years is a long time, the gas may still ...   May 25 2007, 05:53 PM
RoninEclipse2G   While two years is a long time, the gas may still...   May 25 2007, 06:31 PM
Headrage   I would recommend that before you do anything, at ...   May 25 2007, 06:51 PM
ptravnic   FWIW - We had a car here in Buffalo, stored in a n...   May 25 2007, 08:20 PM
orthobiz   Thanks for the suggestions. Some pretty dumb ques...   May 25 2007, 09:23 PM
watsonrx13   When I drained the gas from my tank, I put the old...   May 25 2007, 09:48 PM
Eric_Shea   Drain the rust. Replace all the floor pans, inn...   May 25 2007, 10:42 PM
Pat Garvey   Drain the rust. Replace all the floor pans, in...   May 26 2007, 09:59 PM
orthobiz   But what's the best way to get rid of old, old...   May 26 2007, 03:53 PM
Pat Garvey   But what's the best way to get rid of old, ol...   May 26 2007, 10:04 PM
Porsche Rescue   I suspect the "correct" answer is to tak...   May 26 2007, 04:06 PM
BarberDave   :trophy: Pat: I have a ans. to your ...   May 27 2007, 05:54 AM
Bartlett 914   Getting rid of old gas is a pain. Don't run it...   May 27 2007, 08:21 AM
sendjonathanmail   campfire starter? --JON   May 27 2007, 09:00 AM
orthobiz   Pat: Young Frankenstein Dave: It's MY gas, not...   May 27 2007, 09:19 AM
Vacca Rabite   To get rid of gas, call your local FLAPS and ask w...   May 27 2007, 11:32 AM
orthobiz   Thanks, could "FLAPS" mean Free_Lance ...   May 27 2007, 03:40 PM
BarberDave   :trophy: PAUL: ...   May 28 2007, 05:08 AM
- Lo-Fi Version Time is now: 8th December 2025 - 01:32 AM
