> 914 megasquirt info- Scott's 1.7
Scott-thundercat
post May 14 2007, 11:31 AM
hey, just bought a megasquirt complete kit from DIYautotune. saw a few good threads about em with 914's on here. any other suggestions? i have a stock 1.7 liter. reason i bought it is that my fuel trigger points went out, so 195 vs 145 it wasnt a tough decision since i've been wanting to build one for a few years now.
anyhow any help or tuning tables would be appreciated! i saw the 2 liter tuning tables. anything for a 1.7?
toon1
post May 28 2007, 01:28 AM
QUOTE(Scott-thundercat @ May 27 2007, 01:40 PM) *
okay started up but died nearly at the same time as all previous attempts. at this point i think it is my rediculously oversized injectors- so i am going to see if i can spruce up my stock injectors and get em to work. i originally replaced em cause i thought they were leaking- turned out it was my cold start injector. so i'll put those in and try again.
thanks for the help. when i get it running i'll post up my MSQ file and tables.
Scott
over size injectors???? what kind are they ? what flow rate???
Dude, that changes EVERYTHING
Scott-thundercat   914 megasquirt info- Scott's 1.7   May 14 2007, 11:31 AM
yarin   Check my sig for pics of my install. I posted a lo...   May 14 2007, 11:55 AM
toon1   which version did you buy? MS-I, 2 , V-2.2,3.0? ...   May 14 2007, 12:12 PM
Scott-thundercat   thanks for the quick response guys. version 3 PCB...   May 14 2007, 03:49 PM
toon1   MS-I V.3 three is a good buy. It has alot of optio...   May 14 2007, 05:18 PM
rfuerst911sc   If anyone needs the LC1 O2 sensor itself I have tw...   May 14 2007, 05:43 PM
brer   I'm working on a MSI v3.0 right now as well. ...   May 15 2007, 03:01 PM
bd1308   brer, the MS will actually calculate FI fuel amou...   May 15 2007, 03:05 PM
toon1   the MAP sesnor is the most important item in the M...   May 15 2007, 04:01 PM
hex123   :agree: The tps is very easy I grabbed one from ...   May 15 2007, 06:27 PM
Scott-thundercat   thanks for all the input guys! so far i am on...   May 21 2007, 02:15 AM
Scott-thundercat   nevermind forgot i put pertonix in it! so a ha...   May 21 2007, 02:18 AM
Scott-thundercat   hmmmm. so i have a hall sensor- but i am going to ...   May 21 2007, 02:34 AM
mrhurtalot   whats the cost for a system fora 2.0? id love thi...   May 21 2007, 02:49 AM
Mueller   whats the cost for a system fora 2.0? id love th...   May 21 2007, 03:32 AM
DNHunt   Mike, I think for $247 you get to solder. Not...   May 21 2007, 08:48 AM
toon1   thanks for all the input guys! so far i am o...   May 21 2007, 09:46 AM
yarin   [quote name='Scott-thundercat' post='903058'...   May 21 2007, 09:03 PM
Rick_Eberle   :agree: I'm with the other guys, build it wit...   May 22 2007, 01:31 AM
brer   Hey, I've created a public folder for megasqui...   May 22 2007, 11:05 AM
toon1   Hey, I've created a public folder for megasqu...   May 22 2007, 11:10 AM
brer   PM me with email address to be sent an invitation ...   May 22 2007, 11:15 AM
Scott-thundercat   took the advice and built in everything. i ended ...   May 22 2007, 04:09 PM
Scott-thundercat   hey got it all in and wired- now to see if i can f...   May 25 2007, 10:29 PM
Scott-thundercat   okay- so went to try and start it- the fuel pump r...   May 26 2007, 01:06 AM
toon1   not sure about the pump relay, could be a transist...   May 26 2007, 01:24 AM
Scott-thundercat   okay found out i wired the fuel pump relay wrong- ...   May 26 2007, 09:02 PM
toon1   Hey Scott, ARE YOU RUNNING RESISTORS OR PWM%?...   May 26 2007, 09:34 PM
Scott-thundercat   pwm% i'm running no easy therm- dont know wha...   May 26 2007, 09:47 PM
toon1   OK, use these settings for WE -40*F: 100 ...   May 26 2007, 10:03 PM
Scott-thundercat   http://img.photobucket.com/albums/v447/Scott-thund...   May 26 2007, 10:34 PM
toon1   Ho are you setting your VE table? Are you using...   May 26 2007, 11:26 PM
Scott-thundercat   yeah i used megatune to do it. does it not look r...   May 26 2007, 11:37 PM
toon1   your KPA settings are upside down. are you goin...   May 26 2007, 11:50 PM
Scott-thundercat   okay i copied the table manually in the correct or...   May 27 2007, 12:10 AM
toon1   Strange that it formed like that, maybe mine is wr...   May 27 2007, 12:38 AM
Scott-thundercat   okay started up but died nearly at the same time a...   May 27 2007, 02:40 PM
toon1   okay started up but died nearly at the same time ...   May 28 2007, 01:28 AM
Scott-thundercat   they were 340 cc VW injectors. now have the stoc...   May 29 2007, 12:25 AM
toon1   how long does it run before it dies?   May 29 2007, 09:20 AM
Scott-thundercat   got it to run for 20 seconds at one point. usuall...   Jun 17 2007, 08:01 PM
Scott-thundercat   okay now here's a real puzzler... I have been...   Jul 19 2007, 10:49 PM
Scott-thundercat   So i got it running! turns out that i had use...   Aug 21 2007, 05:14 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:50 PM
