| tracks914 |
May 29 2007, 08:31 PM
Canadian Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
OK - I pulled my old clutch.
Measured the flywheel and 2 spares - 2 were like new the one in my car had been turned down (just the face not the shoulder). Measured my clutch disk - it was like new - 10% wear. Had 3 clutch spring plates - measured travel to center point of spring(using a drill press and tape measure) - 2 @ 3/8" 1 @ 1/2 " (but it had 1/8" more travel before spring plate started to move). Everything looked OK so I put it all back together (using the like new flywheel not the original that appeared to have been turned down). Clutch to flywheel probably had 1/4" to 3/8" of compression with clutch bolts upon assembly. Now clutch works OK - as it did before - but the engagement point of the clutch is just this side of the center point of the spring plate. I can drive it but when pulling away from a stop I have to be careful because the clutch wants to engage just as I get it to the center point and the pressure increases very fast. Besides that, it's annoying as hell every time I engage the clutch it's nice and firm (to the 1/2 way point) then gets really easy to push down just as it disengages and my foot goes to the floor. Any suggestions??? Thanks |
| tracks914 |
May 29 2007, 08:59 PM
Huh? I've looked in my Haynes and found nothing.
Explain please Cap'n. |
tracks914 Still having clutch woes May 29 2007, 08:31 PM
Cap'n Krusty Is your pedal stop in place and properly adjusted?... May 29 2007, 08:44 PM
John He's talking about the pedal stop that is part... May 29 2007, 09:18 PM
So.Cal.914 If it's not grinding the adjustment dosen... May 29 2007, 09:22 PM
tracks914 OK I'm back from the garage. I found the adjus... May 29 2007, 09:30 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th October 2026 - 07:29 AM |
