> What am I missing?
por73914
post May 31 2007, 09:38 AM
I don't know what the hell I am doing...
Ok 74 914 2.0. It has been sitting since 92. Anyway, I am driving it now (IMG:style_emoticons/default/driving.gif) but there is a problem that is driving me crazy. The very first time I turned it over I used the key all was good. Then the key quit working but I had power going into the circuit board but not coming out (I know I need a new board). So I jumped a wire across the board to the YELLOW wire going to the starter and I am drivng again (IMG:style_emoticons/default/driving.gif)! Until I turn it off and now I have no power to the board. (IMG:style_emoticons/default/headbang.gif) So looking at the wiring diagram there is a YELLOW wire going to the board from the ignition then the board then YELLOW to the starter. My 914 does not have a YELLOW wire to the board but has a YELLOW with RED stripe that is from the ignition. In the diagram the only YELLOW with RED stripe wire from the ignition switch goes to the seat belt light...Could that be a problem? (IMG:style_emoticons/default/confused24.gif) The wiring diagram does not show anything between the switch and the board. Switch bad? (IMG:style_emoticons/default/confused24.gif) Now I have a push button to start the car. No Likey Thanks for any ideas. Paul
pin31
post May 31 2007, 11:16 AM
It sounds like the ignition switch. Its a little plastic switch at the end of the key/cylinder assembly in the steering column. I replaced mine, they do easily crack with age. Pelican Parts $7.50
111-905-865K-M61 Ignition Switch, Electrical Portion, 914 1.7/2.0 (1972-74), Each
Dr914's 700 tips book has a good step-by-step procedure on how to replace (need to remove the steering wheel & cylinder assembly etc..)
You should also bypass seatbelt relay (which it sounds like you did - good).
I'm suprised that the relay board is bad, I would remove the T14 & T12 connectors along with the relays and give all the contacts a good cleaning with electrical contact cleaner.
hope this helps,
Tim
- Lo-Fi Version Time is now: 11th August 2026 - 03:49 PM
