Plaindaner |
Plaindaner ![]() Group: Members Posts: 30 Joined: 7-April 07 From: Green Forest, AR Member No.: 7,650 ![]() |
Somehow, the driver side cabin heater hose came loose and found it's way to my fan. The wire from the hose is wrapped around the fan and or shaft. I got as much out as I could. Here's the question, short of dropping the engine, is there a way to get in there and unravel the hose wire? This sucks! (IMG:style_emoticons/default/mad.gif)
sanman |
Leaving California ![]() ![]() Group: Members Posts: 341 Joined: 17-June 04 From: Houston, TX Member No.: 2,219 Region Association: None ![]() |
If its a 4 the fan is direct drive you have to turn the engine to turn the fan if the engine is not locked up the fan is not. you may have to get someone roll the car in gear to spin the engine while you pull the wire with some pliers
Lo-Fi Version | Time is now: 13th May 2025 - 03:56 AM |
