Group buy - Oil ventilation and return system, A Racer Chris & Spunone collaboration! |
ConeDodger |
May 15 2007, 02:30 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
When you modify your car, eliminating what the Porsche engineers designed you have to replace it or risk the consequences. In the case of the oil breather lines that used to go to your intake you risk oil leaks because of pressure and such...
Chris Foley of CFR has come up with the best solution I have seen. It takes the oil vapor from the heads and crankcase and if it pools, automatically drains it back to the engine. See the pic below. Chris would like to build a run of these but in order to justify the time and keep down the costs he needs to build a bunch. So... Once again it is Group Buy time in 914World. Indicate your interest here and Chris will give us details on cost and payment... Attached image(s) |
ChrisFoley |
May 31 2007, 04:53 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I have assembled one unit with the sample spunone provided. It is 4" dia instead of 3.5". Paul says his 3.5" tooling is worn.
The brackets have been modified to move the unit closer to the firewall. The outlet tube is 1" dia. to reduce gas exit velocity. The foam should cause nucleation of the oil vapor and condense it to prevent mist in the engine compartment. I am reducing the price to $130 based on savings from using a spun cannister with one end cap instead of a tube with 2 end caps. For anyone who wants a second fitting for the breather tower, like Craig, the added cost is $10. Pics below: Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 03:54 AM |
