> What am I missing?
por73914
post May 31 2007, 09:38 AM
I don't know what the hell I am doing...
Ok 74 914 2.0. It has been sitting since 92. Anyway, I am driving it now (IMG:style_emoticons/default/driving.gif) but there is a problem that is driving me crazy. The very first time I turned it over I used the key all was good. Then the key quit working but I had power going into the circuit board but not coming out (I know I need a new board). So I jumped a wire across the board to the YELLOW wire going to the starter and I am drivng again (IMG:style_emoticons/default/driving.gif)! Until I turn it off and now I have no power to the board. (IMG:style_emoticons/default/headbang.gif) So looking at the wiring diagram there is a YELLOW wire going to the board from the ignition then the board then YELLOW to the starter. My 914 does not have a YELLOW wire to the board but has a YELLOW with RED stripe that is from the ignition. In the diagram the only YELLOW with RED stripe wire from the ignition switch goes to the seat belt light...Could that be a problem? (IMG:style_emoticons/default/confused24.gif) The wiring diagram does not show anything between the switch and the board. Switch bad? (IMG:style_emoticons/default/confused24.gif) Now I have a push button to start the car. No Likey Thanks for any ideas. Paul
John
post Jun 1 2007, 02:56 PM
member? what's a member?
Be CERTAIN that both battery clamps and posts are clean, tight and are conducting electricity. I recently saw a case where a positive battery clamp was giving all sorts of fits. Sometimes it would click, sometimes nothing. After changing switches and starters, it was found that it was a bad connection at the battery.
Might as well start there as it is an inexpensive thing to check.
Good luck with it.
- Lo-Fi Version Time is now: 11th August 2026 - 03:50 PM
