Group buy - Oil ventilation and return system, A Racer Chris & Spunone collaboration! |
ConeDodger |
May 15 2007, 02:30 PM
Apex killer! Group: Members Posts: 23,606 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
When you modify your car, eliminating what the Porsche engineers designed you have to replace it or risk the consequences. In the case of the oil breather lines that used to go to your intake you risk oil leaks because of pressure and such...
Chris Foley of CFR has come up with the best solution I have seen. It takes the oil vapor from the heads and crankcase and if it pools, automatically drains it back to the engine. See the pic below. Chris would like to build a run of these but in order to justify the time and keep down the costs he needs to build a bunch. So... Once again it is Group Buy time in 914World. Indicate your interest here and Chris will give us details on cost and payment... Attached image(s) |
ChrisFoley |
Jun 5 2007, 01:12 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The stock pcv fitting (which must be gutted for this application) accepts a 1/2" hose nicely. I guess you need a sleeve that fills the space between your hose and the 1/2" tube I used. The sleeve could be glued to the 1/2" tube.
The other fittings are 1/2" too. You must have used -8 hose for them. I have considered adding another fitting (up high) for the crankcase as a standard item that could be capped if unused. It may enhance the flow of crankcase gases to have a separate line for the oil drainage. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:36 AM |
