Engine Oil Leaks, Engine Oil Leaks |
KJJ-74-914 |
Nov 28 2003, 04:10 PM
Newbie Group: Members Posts: 30 Joined: 28-November 03 From: Antioch, IL Member No.: 1,401 |
After letting my 1974 914 sit this year, I decided to pull the engine this morning to start my winter project of replacing the leaking seals. The engine is a 1.8 with 2.0 bore cylinders, euro pistons and fuel injection. The engine has 3000+- miles on it and is a great runner!! It started leaking oil 2 years ago so I decided not to drive it until I fixed the leaks.
I plan on replacing the oil cooler seals, pushrod tube seals and pressure switch. What else should I replace? Best sources? Also, the thermostatic cooling set up has been disconnected and I'd like to repair it. This is the flapper under the cooling shroud with the cable that runs down to a cam that appears to temperature controlled. Where can I get parts for this system or am I better off leaving it disconnected? Thanks in advance. Kirk |
Lo-Fi Version | Time is now: 11th June 2024 - 05:29 PM |
