> Using a 72 Beetle Turn Signal Switch, Does this work?....wiring differences?
PRS914-6
post Jun 15 2007, 09:53 AM
Excellence Magazine Project 914 3.6
Group: Retired Members
After searching awhile it appears the 72 style turn signal switch is NLA from Porsche. It looks like some have use the 72 Beetle switch with success. Looking at This Web Site they look the same but the wiring colors are different. It also looks like there is only one rub arm for the horn contact instead of two.
Anyone have experience with this? It looks like the colors are different but set up the same. Are the connectors the same? Wire length the same? or basically, is there any issues installing these?
krazykonrad
post Jun 17 2007, 10:17 PM
I know that at least externally the turn signal switch on my 72/ 4 is the same as my dad's 72 Super Beetle (as is the rest of the steering column). As far as the insides, I'm not sure, but I bet its probably the same part.
Konrad
PRS914-6   Using a 72 Beetle Turn Signal Switch   Jun 15 2007, 09:53 AM
boxstr   Paul, Not sure about the ones you are looking at. ...   Jun 15 2007, 10:47 AM
Cap'n Krusty   Because the switch is German, and especially becau...   Jun 15 2007, 12:08 PM
PRS914-6   Thanks for the replies. I ordered an OEM and paid...   Jun 15 2007, 01:04 PM
Marlow   I found the Beetle part to fit perfectly in my 74....   Jun 15 2007, 02:41 PM
PRS914-6   Thanks Joel, I wanted to put an OEM style in. Had...   Jun 15 2007, 03:41 PM
dr914@autoatlanta.com   The best thing to do in this case is not to suffer...   Jun 15 2007, 04:18 PM
Al Meredith   15 years ago I replaced the turn signal switch on ...   Jun 15 2007, 05:20 PM
914Sixer   I bought two switches this month for my 73. One w...   Jun 16 2007, 09:53 AM
rick 918-S   What part fails on this switch? The cancel? or the...   Jun 16 2007, 10:08 AM
dr914@autoatlanta.com   What part fails on this switch? The cancel? or th...   Jun 16 2007, 12:27 PM
914Sixer   I have added some pictures for inquiring minds tha...   Jun 17 2007, 08:08 PM
krazykonrad   I know that at least externally the turn signal sw...   Jun 17 2007, 10:17 PM
Marlow   As it turns out the aftermarket part I bought for ...   Jun 17 2007, 10:36 PM
Air_Cooled_Nut   Speaking of turn signal lever, is the hi/low beam ...   Jun 18 2007, 01:11 PM
Marlow   Yes, the dimmer switch is built into the turn sign...   Jun 18 2007, 01:57 PM
Air_Cooled_Nut   No idea. It's a 1973 car, originally 1.7L.   Jun 18 2007, 11:05 PM
mightyohm   I can confirm that a 1972 VW Beetle turn signal sw...   Oct 6 2009, 01:47 AM
tat2dphreak   can you also get the equivalent wiper switch? that...   Oct 6 2009, 07:51 AM
mightyohm   can you also get the equivalent wiper switch? tha...   Oct 8 2009, 01:42 AM
McMark   Lookin' good. One more pesky problem off the ...   Oct 6 2009, 02:30 PM
silverteener   I used a VW one on my 72 also. I think I got mine...   Oct 6 2009, 02:41 PM
- Lo-Fi Version Time is now: 29th October 2026 - 01:02 PM
