> How stiff can you go, Rear springs
brilliantrot
post Jun 19 2007, 03:29 PM
So I am just begining to see why people always sa race cars are never done. I just ran my first autocross on track tires (Nitto NT-01s) and now my previously perfect handeling car lifts front wheels way into the air. Corner workers were saying as high as six inches!!! Now I am NO expert but this leads me to believe that there is still a considerable amount of time to be had if I can keep the wheels on or alot nearer to the ground. My question is how stiff to go in the rears. I currently have #140 Weltmeisters on the back and stock front torshens with a H&H 19mm ajustable front sway bar set one hole from soft leaving two stiffer settings (four holes total). I am thinking #175 or #200 2.5inch springs on ajustable perches. Any suggestions? Will ajusting the front bar to full stiff be enough to counteract springs this stiff? This is for a strictly autocross car that only gets driven to events and on the occassional sunny day. Also it has a six pt. cage.
Any input will be appriciated since I would only like to buy one more set of springs.
Attached File(s)
brilliantrot
post Jun 20 2007, 03:20 PM
Right now I am running probably the cheapest suspention upgrades that one could do. The rear shocks are red Konis, the ones that you have to remove the spring and fully compress to ajust, that came on the car when I bought it about four years ago. When I put on the #140 rear springs I ajusted the Konis to full stiff because I figured they would need to be firmer to compensate for the stiffer springs. When get new springs I will definatly buy new shocks because I found out the hard way why they reccomend using three of the skrew type spring compressors instead of two. Dentist bills cost way more than a new set of Koni Sports. The rear bushings are Elephant Poly Bronz so they sre probably not the problem. By the way if any one is considering these bushings I highly recomend them. They inproved the ride quality over worn stock bushings and I was able to install them without disconecting the brake lines. The only downsides are that the grease fitting holes a hard to drill, broke about five, and tap and the new bar bolt thing that the bushings rotate on is not hollow like the original one so it is about twice as heavy.
From the sounds of things I should save my money and get 21mm front torshens #250 ish springs and a full set of Koni Sports to replace my questionable rear shocks and my front KYBs. By the way I found 3.75 inches at the front jack points to be to low. I blew out the drivers shock and even now with new KYBs, were new in the box left over from another project not my first choice but made it easy and cheap, and 4inches at the front jack points I only have about .75inches of travel before my shortened bump stops start to work. Thank you guys for all of your imput on the black art of suspention tuning.
brilliantrot   How stiff can you go   Jun 19 2007, 03:29 PM
john rogers   The way it was explained to me was "if a corn...   Jun 19 2007, 03:56 PM
brilliantrot   What does one do about the front if #300 springs a...   Jun 19 2007, 04:04 PM
Joe Ricard   Well I just jumped up to 300lb rears, This is up ...   Jun 19 2007, 08:22 PM
john rogers   It's not the HP, it's the cornering abilit...   Jun 19 2007, 09:01 PM
brilliantrot   I know all about beating "faster" cars. ...   Jun 19 2007, 09:18 PM
Dave_Darling   Has eneyone succesfully run #200 springs without a...   Jun 19 2007, 11:50 PM
SirAndy   front: - stock 911 ('84 carrera) T-Bars - 22mm...   Jun 19 2007, 09:45 PM
grantsfo   So I am just begining to see why people always sa...   Jun 20 2007, 08:18 AM
Joe Ricard   I looed back in my log books, For a brief time I h...   Jun 20 2007, 11:48 AM
brilliantrot   Right now I am running probably the cheapest suspe...   Jun 20 2007, 03:20 PM
SirAndy   I only have about .75inches of travel before my ...   Jun 20 2007, 03:50 PM
brilliantrot   I drive my car so infrequently that I do not even ...   Jun 20 2007, 03:55 PM
ChrisNPDrider   Are those Nittos the ones with all the curvy groov...   Jun 20 2007, 03:56 PM
brilliantrot   I have only run one event on them, 11 runs of a 1....   Jun 20 2007, 04:58 PM
brilliantrot   I hve to run a .25 inch spacer in the back and am ...   Jun 20 2007, 05:00 PM
Joe Ricard   Hmm nice braking. 100 to 50 in 50 feet. I am ...   Jun 29 2007, 04:24 PM
Borderline   Assuming my physics classes from thirty years ago ...   Jun 29 2007, 09:48 PM
Joe Ricard   That is some heavy duty braking with alot of other...   Jun 30 2007, 07:41 AM
brilliantrot   The braking distance and speeds stated are just my...   Jul 6 2007, 03:41 PM
sean_v8_914   give him bad advise...he's going to catch me ...   Jul 18 2007, 03:53 PM
- Lo-Fi Version Time is now: 16th June 2024 - 08:51 PM
