Intermittant Wiper Installation Question, Can I test the Signal Wire ? |
jim_hoyland |
Jun 20 2007, 09:17 PM
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I have the intermittant wiper harness ready to install and want to test the signal wire first. I untaped the brown wire/blk stripe that was folded back on the loom going toward the wiper motor. Should I get 12 v signal in that wire with the ignition on, and wiper switch in the full-down position ( i removed the tap) ?
I stuck a grounded test light into the connector with the switch on and got NADA Perhaps someone who has does this retro-fit can halp.The wiper switch is either a late model VW or 924. It runs the washer pump in the pull-bak position Thanks, Jim |
904svo |
Jun 20 2007, 10:40 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
I believe the wipers have to turn on first for it to work.
jim_hoyland |
Jun 20 2007, 10:46 PM
I believe the wipers have to turn on first for it to work. I ran the wiper slow first, then moved the switch position to one below the off. I guess I'm wondering if the brown wire/blk stripe is a ground ? Looking for someone who has done this install and did some trouble shooting Jim |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:53 AM |
