Group buy - Oil ventilation and return system, A Racer Chris & Spunone collaboration! |
ConeDodger |
May 15 2007, 02:30 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
When you modify your car, eliminating what the Porsche engineers designed you have to replace it or risk the consequences. In the case of the oil breather lines that used to go to your intake you risk oil leaks because of pressure and such...
Chris Foley of CFR has come up with the best solution I have seen. It takes the oil vapor from the heads and crankcase and if it pools, automatically drains it back to the engine. See the pic below. Chris would like to build a run of these but in order to justify the time and keep down the costs he needs to build a bunch. So... Once again it is Group Buy time in 914World. Indicate your interest here and Chris will give us details on cost and payment... Attached image(s) |
Aaron Cox |
Jun 11 2007, 10:17 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
you can put bungs (bolt in) on your valve covers themselves... or you can tap the boss on your heads.
ChrisFoley |
Jun 28 2007, 05:51 PM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
you can put bungs (bolt in) on your valve covers themselves... or you can tap the boss on your heads. I recommend tapping the heads in the stock location for 1/4"npt X 1/2"hose nipple adapters. If you vent the valve covers the hoses will have to come up through the tin somewhere. |
Lo-Fi Version | Time is now: 10th June 2024 - 11:25 AM |
