> OEM Rear Sway Bar Endlinks:, best way to press bushings? Help!
Johny Blackstain
post Jun 30 2007, 06:44 AM
So I'm working on making the underside of the LE as pretty as the topside, pull the end links off the rear sway bar & the bushings just disintegrate into yellow crumbs. Yes, I'm changing all my suspension bushings! No big deal, been sitting on new bushings for 3 years & I need to use them now. So how the hell do they get pressed in? I'm having much difficulty in this step & I have a press! I also foresee much difficulty getting them onto the ball mounts on the end of the sway bar. Any thoughts, ideas, recommendations? Thanks
(IMG:style_emoticons/default/cool_shades.gif)
73Phoenix20
post Jun 30 2007, 08:01 AM
Warm all of the components up in a 200 degree oven for a few minutes...
Then (with silicone oven gloves!) carefully press the bushings into the drop links, using a bench vise and a bit of dish soap to lube things up... I like Dawn!
To get the bushings back onto the suspension points, I used a large "C" Clamp, with the screw type jaws, and after careful aligning, just kept tightening until it popped on!
Have fun!
- Lo-Fi Version Time is now: 2nd April 2026 - 10:20 AM
