> OEM Rear Sway Bar Endlinks:, best way to press bushings? Help!
Johny Blackstain
post Jun 30 2007, 06:44 AM
So I'm working on making the underside of the LE as pretty as the topside, pull the end links off the rear sway bar & the bushings just disintegrate into yellow crumbs. Yes, I'm changing all my suspension bushings! No big deal, been sitting on new bushings for 3 years & I need to use them now. So how the hell do they get pressed in? I'm having much difficulty in this step & I have a press! I also foresee much difficulty getting them onto the ball mounts on the end of the sway bar. Any thoughts, ideas, recommendations? Thanks
(IMG:style_emoticons/default/cool_shades.gif)
73Phoenix20
post Jun 30 2007, 11:04 AM
I now wonder if a large jawed "Welding" Visegrip type tool could be used to pop the Bushings over the Balls???
Be sure to lube your "Balls" before you try an "Pop" them!!!
- Lo-Fi Version Time is now: 2nd April 2026 - 08:47 AM
