how to figure shims 4 compression ratio, 2056 jug spacing |
orange914 |
Jul 2 2007, 12:26 AM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
i'll be putting together a 2056 soon. with jakes 9050 cam can i run d-jet and 9.0:1 on pump gas with no problem?
can i be pointed to a thread on this set up proceedure? (IMG:style_emoticons/default/smile.gif) |
ptravnic |
Jul 2 2007, 10:55 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
i'll be putting together a 2056 soon. with jakes 9050 cam can i run d-jet and 9.0:1 on pump gas with no problem? can i be pointed to a thread on this set up proceedure? (IMG:style_emoticons/default/smile.gif) This is a good example of why it is very important to take your time (which will be frustrating). Need the heads cc'd and deck height measured to determine which shims are needed to get the CR you desire. After this is sorted and the right shiims are in and the heads are torqued down, it'll be time to start learning about rocker arm geometry. 911 swivel feet adjusters, adjustable push rod, cut to fit push rod's... At first you (as I did) probably thought that once the parts arrive it's time to put it all together - maybe even in a day or a weekend BUT rarely does it happen that way. Enjoy the process! |
orange914 |
Jul 3 2007, 12:28 AM
i'll be putting together a 2056 soon. with jakes 9050 cam can i run d-jet and 9.0:1 on pump gas with no problem? can i be pointed to a thread on this set up proceedure? (IMG:style_emoticons/default/smile.gif) This is a good example of why it is very important to take your time (which will be frustrating). Need the heads cc'd and deck height measured to determine which shims are needed to get the CR you desire. Enjoy the process! thanks, i wont rush the build. just learning alot and trying to acumulate the right parts. lots to do you now, hurry up -n- wait |
Lo-Fi Version | Time is now: 1st June 2024 - 02:05 PM |
