Installing distributor pinion gear, at right angle |
thomasotten |
Jul 6 2007, 08:35 AM
Senior Member Group: Members Posts: 1,547 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
So, I was thinking about this on the way to work. When rebuilding an engine, how do you make sure that the distributor pinion gear is going in at the right angle? I watched Jake's video, where he set the rotor to line up with the notch on the distributor housing, then stabs the distributor and the pinion gear at the same time. But, then, doesn't that assume that your distributor was timed and not moved when you took it off? Mine has the fastening clamp removed already. Will it ever really matter?
IronHillRestorations |
Jul 6 2007, 10:24 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You've got to get the engine at TDC #1, and then install the drive gear at the correct angle. I don't know it right off hand, but the description in the Haynes manual is fairly easy.
The drive on the gear and the bottom of the distributor is offset and the distributor will only go in one way. I use an old drum stick with the tip broken off and it wedges in the drive gear perfectly. It makes removal and install easy. |
Lo-Fi Version | Time is now: 11th June 2024 - 02:12 AM |
