QUOTE(9146986 @ Jul 6 2007, 11:24 AM)
You've got to get the engine at TDC #1, and then install the drive gear at the correct angle. I don't know it right off hand, but the description in the Haynes manual is fairly easy.
The drive on the gear and the bottom of the distributor is offset and the distributor will only go in one way.
I use an old drum stick with the tip broken off and it wedges in the drive gear perfectly. It makes removal and install easy.
java script:emoticon(':agree:', 'smid_8')
The Haynes manual has a nice description. The slot in the top of the distributor drive shaft should be at a 12 degree angle to the split line of the engine case. The slot is slightly offset; the smaller part goes to the outside. The manual has a nice picture. The shaft will rotate when you install it and the gears engage, so you'll have to start out at a different angle than 12 deg.
It only *really* matters if the vacuum cannister hits the engine tin, although it could be a bit confusing to the next guy when the spark plug wires appear to go to the wrong towers on the cap.
The PO installed mine wrong and I'm too scared of dropping the washer or spring into the case to have a go at fixing it.
