Installing distributor pinion gear, at right angle |
thomasotten |
Jul 6 2007, 08:35 AM
Senior Member Group: Members Posts: 1,545 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
So, I was thinking about this on the way to work. When rebuilding an engine, how do you make sure that the distributor pinion gear is going in at the right angle? I watched Jake's video, where he set the rotor to line up with the notch on the distributor housing, then stabs the distributor and the pinion gear at the same time. But, then, doesn't that assume that your distributor was timed and not moved when you took it off? Mine has the fastening clamp removed already. Will it ever really matter?
IronHillRestorations |
Jul 6 2007, 10:24 AM
You've got to get the engine at TDC #1, and then install the drive gear at the correct angle. I don't know it right off hand, but the description in the Haynes manual is fairly easy.
The drive on the gear and the bottom of the distributor is offset and the distributor will only go in one way. I use an old drum stick with the tip broken off and it wedges in the drive gear perfectly. It makes removal and install easy. |
toomanyinkc |
Jul 6 2007, 11:41 AM
Member Group: Members Posts: 67 Joined: 8-February 07 From: Kansas City Member No.: 7,509 |
You've got to get the engine at TDC #1, and then install the drive gear at the correct angle. I don't know it right off hand, but the description in the Haynes manual is fairly easy. The drive on the gear and the bottom of the distributor is offset and the distributor will only go in one way. I use an old drum stick with the tip broken off and it wedges in the drive gear perfectly. It makes removal and install easy. java script:emoticon(':agree:', 'smid_8') (IMG:style_emoticons/default/agree.gif) The Haynes manual has a nice description. The slot in the top of the distributor drive shaft should be at a 12 degree angle to the split line of the engine case. The slot is slightly offset; the smaller part goes to the outside. The manual has a nice picture. The shaft will rotate when you install it and the gears engage, so you'll have to start out at a different angle than 12 deg. It only *really* matters if the vacuum cannister hits the engine tin, although it could be a bit confusing to the next guy when the spark plug wires appear to go to the wrong towers on the cap. The PO installed mine wrong and I'm too scared of dropping the washer or spring into the case to have a go at fixing it. |
Gint |
Jul 6 2007, 06:05 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
The PO installed mine wrong and I'm too scared of dropping the washer or spring into the case to have a go at fixing it. (IMG:style_emoticons/default/laugh.gif) Same here... and the 009 doesn't care where its pointed so neither do I. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:58 AM |
