Group buy - Oil ventilation and return system, A Racer Chris & Spunone collaboration! |
ConeDodger |
May 15 2007, 02:30 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
When you modify your car, eliminating what the Porsche engineers designed you have to replace it or risk the consequences. In the case of the oil breather lines that used to go to your intake you risk oil leaks because of pressure and such...
Chris Foley of CFR has come up with the best solution I have seen. It takes the oil vapor from the heads and crankcase and if it pools, automatically drains it back to the engine. See the pic below. Chris would like to build a run of these but in order to justify the time and keep down the costs he needs to build a bunch. So... Once again it is Group Buy time in 914World. Indicate your interest here and Chris will give us details on cost and payment... Attached image(s) |
thomasotten |
Jul 7 2007, 10:02 PM
Senior Member Group: Members Posts: 1,547 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
I'm a fence sitter here. Does anyone see a problem with mounting this outside the engine compartment, under the fender?
ConeDodger |
Jul 7 2007, 10:21 PM
I'm a fence sitter here. Does anyone see a problem with mounting this outside the engine compartment, under the fender? Tom, I can see your problem. Your car is very original looking. The problem is the design. The bottom outlet in the front is meant to both recieve outlet pressure from the crankcase as well as gravity drain any oil that makes its way up to the canister. Under the fender you lose gravity. This thing mounts easily with a little trim of the back insulation. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:43 AM |
