Air compressor question, Draining the water, but leaving it pressurized overnight |
VaccaRabite |
Jul 18 2007, 02:05 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have a question about my air compressor.
Lately I have been turning it off when I am done working, then draining the water out via the drain plug. But once the water was out, I was leaving it pressurized for the next day. I figure that is less wear and tear then having to re-pressurize the tank every day that you need to do work, and would save time if you needed air for some other task (like charging a bike tire before going riding). if the tank was fully pressurized before I turn the compressor off, it could have ~100 psi of air after draining the water out of the bottom of the tank. Is this harmfull? I am taking the pressure out of the hose and setting my regulator for 0 PSI, so I don't think it would strain the regulator. Am I wrong here? Zach |
rhodyguy |
Jul 18 2007, 04:32 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
when you release the air draining it and represurize it, you fill it back up with moist air. which will condense and form water...again. when done for the day, drain it and close the petcock the next time you use it. under constant use on a job site they cycle up alot.
k |
Lo-Fi Version | Time is now: 1st June 2024 - 01:56 PM |
