Russ |
Newbie ![]() Group: Members Posts: 34 Joined: 31-July 06 From: W. Columbia Member No.: 6,544 ![]() |
Histroy:
Recently my "14" was left in the rain due to a surprise thunder strom. The car is a semi track car, so it does not have a rain gaurd, with that said you should now were this is headed. So far I have removed the carbs and disassembled them, cleaned out the water, and reassembled the units, and reattached to the motor. Fired the car up and went for a test drive. The problem: With the car warmed-up and traveling at a steady velocity/ RPM ( 3000< RPM) the car is spitting/ or miss firing and when the accelerator pedal is released there is a great deal of popping thru the exhaust. Any help or suggestions would be greatly appreciated. Russell Turpin 803-606-7269 turpin0801@aol.com Attached File(s) ![]() |
JPB |
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 ![]() |
Did ya tighten them down good on the intakes and use new gaskets? (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 2nd July 2025 - 10:26 PM |
