terrymason |
Member ![]() ![]() Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 ![]() |
The problem - The car will go very lean around 2500 rpm, as if the pump jets were too small.
History: New fuel pump (3.5 PSI to each carb) 55 idle jets 55 pump jets 140 main jets 175 air correctors These carbs are new to the car, and I'm trying to dial them in. The car is lean when I first start it (16 / 17 on my air / fuel gauge), but then levels out to a nice 14.7 idle when warmed up. While driving, I can give the car 20% or so of the pedal, and drive up to highway speeds nicely, but when I goose it, it will go very lean (18-22 on my gauge) followed by a series of backfires and loss of power. I started off with 35 pump jets, and have moved up to 55s, which appear to be the most popular around here. I've also adjusted the pump jet linkage, from the nut fully loosened, and moved it in as far as it would go before affecting the main throttle shaft (like 60 turns or something). What do you guys think, do I need 75 pump jets? |
terrymason |
I'm back in town, and had some time to look at my Dells. I took out the venturis, and I was finally able to find a 34 etched by hand on one end of each. It looks like they were larger, then were milled down.
I'm still waiting on my new 30 venturis. and will report back when I get them |
BxtrBill |
Newbie ![]() Group: Members Posts: 23 Joined: 31-December 05 From: Arcadia, CA Member No.: 5,342 ![]() |
QUOTE I'm still waiting on my new 30 venturis. and will report back when I get them You might want to order some smaller main jets while you're at it....those 140s are gonna be way on the rich side, especially with the 175 airs. Rule-of-thumb says 120s should work...125s may be better. Too lean typically ain't good. |
Lo-Fi Version | Time is now: 4th July 2025 - 04:33 AM |
