| seanery |
Dec 3 2003, 07:05 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I'm trying to figure out how to build a good fire quickly. I just switched from wood tee pee newspaper under to wood tee pee newspaper ON the grate. It worked great!
| Aaron Cox |
Dec 3 2003, 07:07 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
you forgot...brake cleaner and wood (IMG:style_emoticons/default/ohmy.gif)
seanery OT-Building A Fire Dec 3 2003, 07:05 PM
sj914 i just press a little button on a remote and up go... Dec 3 2003, 07:07 PM
robby750 Go buy a box of fire starter logs. Made out of sa... Dec 3 2003, 07:20 PM
redshift Three wood components.
Cured split hardwood logs,... Dec 3 2003, 07:24 PM
GWN7 Stack your wood and use a propane torch to get it ... Dec 3 2003, 07:36 PM
URY914 Why would you want to start a fire? Dec 3 2003, 07:46 PM
Mark Henry
! I have been banned from starting fires in in the f... Dec 3 2003, 07:50 PM
nebreitling don't change your fuel lines.
i hear it works... Dec 3 2003, 07:50 PM
Qarl Newspaper crumpled, with split pine kindling, then... Dec 3 2003, 07:52 PM
redshift Here is a link to the splitter I use:
http://clie... Dec 3 2003, 08:15 PM
Aaron Cox LOL.... Dec 3 2003, 08:22 PM
GWN7 Miles,
Try putting insulation in your walls & roo... Dec 3 2003, 08:24 PM
redshift coffee+keyboard=delusional psychoid
it's gett... Dec 3 2003, 08:24 PM
Doug Leggins This old house was built in 1935 - very little ins... Dec 3 2003, 08:28 PM
Gint Dood....
Charcoal lighter fluid works GREAT! Dec 3 2003, 08:28 PM
Mark Henry
Gint You don't have to be a moron about it. Some l... Dec 3 2003, 09:02 PM
Bruce Allert
redshift
GWN7 Well I live in an igloo. 2 ft. thick walls. I can ... Dec 3 2003, 09:54 PM
campbellcj The newer construction out in these parts can... Dec 3 2003, 10:12 PM
seanery Chris,
whatayamean? (about the newer construction) Dec 3 2003, 10:16 PM
Aaron Cox my house was built w/ gas. we burn wood. a chimney... Dec 3 2003, 10:17 PM
campbellcj I could be wrong, but I recall being told it is "i... Dec 3 2003, 10:27 PM
seanery i gotcha on that one chris, embers possible floati... Dec 3 2003, 10:51 PM
campbellcj There is about 8 miles of "nothing" (brush and tre... Dec 4 2003, 12:15 AM
! Fire issues and the smoke from fire places cause n... Dec 4 2003, 12:19 AM
GWN7 You can check with your local Fire Department for ... Dec 4 2003, 01:46 AM
Bruce Allert I was brought up using no grate. Grates weren... Dec 4 2003, 08:02 AM
Lawrence Newspaper? We don't need no stinkin newspaper... Dec 4 2003, 08:09 AM
! Creosote?????
WYF, you burning RAILROAD ties agai... Dec 4 2003, 08:27 AM
Joe Ricard Yup gas in a teener + hot water heater = hotter th... Dec 4 2003, 09:31 AM
Racer I just back my Pinto up into a tree.. crude but ef... Dec 4 2003, 10:25 AM
GWN7 Creosote is the product of incompleat combustion. ... Dec 4 2003, 01:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:29 AM |
