> OT-Building A Fire, How Do You Do It?
How Do You Build Your Fire?
Newspaper wadded up UNDER grate Wood Stacked [ 8 ] ** [20.51%]
Newspaper wadded up ON grate Wood Stacked [ 5 ] ** [12.82%]
No Newspaper Wood Stacked [ 1 ] ** [2.56%]
Newspaper wadded UNDER grate Wood Tee Pee [ 6 ] ** [15.38%]
Newspaper wadded ON grate Wood Tee Pee [ 1 ] ** [2.56%]
No Newspaper Wood Tee Pee [ 0 ] ** [0.00%]
I use Dura Flame logs [ 2 ] ** [5.13%]
I have Gas Logs! [ 6 ] ** [15.38%]
I don't have a fireplace :( [ 4 ] ** [10.26%]
Other: Describe Below [ 6 ] ** [15.38%]
Total Votes: 39
Guests cannot vote
seanery
post Dec 3 2003, 07:05 PM
waiting to rebuild whitey!
I'm trying to figure out how to build a good fire quickly. I just switched from wood tee pee newspaper under to wood tee pee newspaper ON the grate. It worked great!
campbellcj
post Dec 3 2003, 10:12 PM
I can't Re Member
The newer construction out in these parts can't have woodburning fireplaces (IMG:style_emoticons/default/sad.gif) But we have two of those gas-burning ones and they work surprisingly well and actually look pretty nice too. Cleaner, cheap and easy to light...just not quite the same as the "real thing" with the aromas and crackles, but what can ya do (IMG:style_emoticons/default/confused24.gif)
seanery   OT-Building A Fire   Dec 3 2003, 07:05 PM
Aaron Cox   you forgot...brake cleaner and wood :o   Dec 3 2003, 07:07 PM
sj914   i just press a little button on a remote and up go...   Dec 3 2003, 07:07 PM
robby750   Go buy a box of fire starter logs. Made out of sa...   Dec 3 2003, 07:20 PM
redshift   Three wood components. Cured split hardwood logs,...   Dec 3 2003, 07:24 PM
GWN7   Stack your wood and use a propane torch to get it ...   Dec 3 2003, 07:36 PM
URY914   Why would you want to start a fire?   Dec 3 2003, 07:46 PM
Mark Henry
!   I have been banned from starting fires in in the f...   Dec 3 2003, 07:50 PM
nebreitling   don't change your fuel lines. i hear it works...   Dec 3 2003, 07:50 PM
Qarl   Newspaper crumpled, with split pine kindling, then...   Dec 3 2003, 07:52 PM
redshift   Here is a link to the splitter I use: http://clie...   Dec 3 2003, 08:15 PM
Aaron Cox   LOL....   Dec 3 2003, 08:22 PM
GWN7   Miles, Try putting insulation in your walls & roo...   Dec 3 2003, 08:24 PM
redshift   coffee+keyboard=delusional psychoid it's gett...   Dec 3 2003, 08:24 PM
Doug Leggins   This old house was built in 1935 - very little ins...   Dec 3 2003, 08:28 PM
Gint   Dood.... Charcoal lighter fluid works GREAT!   Dec 3 2003, 08:28 PM
Mark Henry
  Dec 3 2003, 08:59 PM
Gint   You don't have to be a moron about it. Some l...   Dec 3 2003, 09:02 PM
Bruce Allert     Dec 3 2003, 09:16 PM
redshift
  Dec 3 2003, 09:24 PM
GWN7   Well I live in an igloo. 2 ft. thick walls. I can ...   Dec 3 2003, 09:54 PM
seanery   Chris, whatayamean? (about the newer construction)   Dec 3 2003, 10:16 PM
Aaron Cox   my house was built w/ gas. we burn wood. a chimney...   Dec 3 2003, 10:17 PM
campbellcj   I could be wrong, but I recall being told it is "i...   Dec 3 2003, 10:27 PM
seanery   i gotcha on that one chris, embers possible floati...   Dec 3 2003, 10:51 PM
campbellcj   There is about 8 miles of "nothing" (brush and tre...   Dec 4 2003, 12:15 AM
!   Fire issues and the smoke from fire places cause n...   Dec 4 2003, 12:19 AM
GWN7   You can check with your local Fire Department for ...   Dec 4 2003, 01:46 AM
Bruce Allert   I was brought up using no grate. Grates weren...   Dec 4 2003, 08:02 AM
Lawrence   Newspaper? We don't need no stinkin newspaper...   Dec 4 2003, 08:09 AM
!   Creosote????? WYF, you burning RAILROAD ties agai...   Dec 4 2003, 08:27 AM
Joe Ricard   Yup gas in a teener + hot water heater = hotter th...   Dec 4 2003, 09:31 AM
Racer   I just back my Pinto up into a tree.. crude but ef...   Dec 4 2003, 10:25 AM
GWN7   Creosote is the product of incompleat combustion. ...   Dec 4 2003, 01:18 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:28 AM
