Harness Installation Question |
Chuck |
Aug 1 2007, 12:35 PM
What it eventually will look like . . . . Group: Members Posts: 355 Joined: 29-March 07 From: Maple Grove, MN Member No.: 7,632 Region Association: Northstar Region |
I picked up a set of new and never used 4 point harnesses from my brother along with some used Sparco seats. The harnesses have the bolt through attachment versus the wrap around the bar attachment for the shoulder straps. Due to concerns about spinal compression in the event of an accident, I don't really like the option of bolting through the firewall.
Is there a harness bar out there that has bolt on attachment for the belts? Alternatively, is there a special mount for connecting the bolt end to a harness bar? Thanks. |
So.Cal.914 |
Aug 1 2007, 12:39 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
I have seen them bolted thru the fire wall, just make sure that the belt is not below the sholders.
SirAndy |
Aug 1 2007, 01:15 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have seen them bolted thru the fire wall, just make sure that the belt is not below the sholders. (IMG:style_emoticons/default/agree.gif) bolt through the firewall is not a problem as long as the bolts are in the right place. you don't want them much lower than your shoulders. if they're level with your shoulders, there's no way of compressing the spine ... (IMG:style_emoticons/default/bye1.gif) Andy PS: if the seats are too high, mount them directly to the floor. |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:13 AM |
