jaybird840 |
Member ![]() ![]() Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region ![]() |
Replacing the NONEXISTENT shifter bushings in my '75 teener and have read and re-read the Pelican article. I have removed the rear tapered screw but was unsuccessful in removing the shift head from the shifter bar in the rear. I wanted to check here before I moved to a bit more persuasion. If they put a cone screw there, I assume that means it separates.... Should just tap off the end of the shift rod with the cone screw removed, right?
--Jaybird ![]() |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Did ya lube it?
If it feels like it is binding you may have trouble getting into some gears which will require you to adjust the shifter on the front section of the front rod. Remember to only move the coupler one spline at a time and they are very fine splines. |
Lo-Fi Version | Time is now: 5th July 2025 - 02:04 AM |
